bbc springs
quake
toyota tech
Apr 13, 2005
619
r.i.
can't find the tech info on the bbc springs i have. Part # 975-12 comp cam. What can you rev them to with upgraded cams? Will they make it to 8k?
92nsx
2,957
Clearwater, MN
You could try but reving that high I would go with Ferrea duel spring valvetrain. To keep valve float to a min. ;)
Also depends on the lift on the cams you are looking at. I know there is something like you only want to compress the spring something 70-80% IIRC. There is a term for it but I forget.
92nsx
2,957
Clearwater, MN
I am running comp cam BBC springs with 272 cams and no problems what so ever here. But I am not reving any where close to that high ;)
quake
toyota tech
Apr 13, 2005
619
r.i.
blackkarma;1387671 said:
alittle off topic...quake how many feet of piping did u use on your exhaust
not sure but i started at the about the front of the door. It was one solid stick
quake
toyota tech
Apr 13, 2005
619
r.i.
think i'm gonna give comp a call with my specs as they are mild regrinds for good reason. I should mention that float is not what i was worried about as i now have solid buckets.
quake
toyota tech
Apr 13, 2005
619
r.i.
just got the go ahead from suprarich! I'll let you guys know if it blows up lol:biglaugh:
I prefer duals for the peace of mind if I'm going to rev an engine that hard.
quake
toyota tech
Apr 13, 2005
619
r.i.
i'm still gonna sleep like a baby:sarcasm: anything breaks on this motor i will let you all know and let you know why so i can move forward.
suprarich
Guest
Nov 9, 2005
2,187
ohio
8k would be nothing for your regrinds on a 83 lb seat pressure 127 lb open spring. And before anyone jumps in and says that is not the seated spec for that spring, it is at our installed height. What is the lift on your cams anyhow? Comp suggest not going any closer to .050 to coil bind.
Edit: And IJ is right. Nothing is safer than duals, but 8k is not out of bounds for that comp spring.
quake;1387852 said:
i thought you determined it was a problem with friction against another spring?
No after speaking with 1/2 doz spring manufacturers duals use a slight interference fit between inners and outers as a damper.
As I said in the PM I still think it was more of a xxx time spent above 8000 as there were 4 other springs that had dropped 15psi seat pressure.
quake
toyota tech
Apr 13, 2005
619
r.i.
lift is just .334"
quake
toyota tech
Apr 13, 2005
619
r.i.
i did check spring press last time they were out and they were all still even. I did not want to use a dual setup with high spring press as i have a 6 angle valve job
