blackkarma;1387671 said:alittle off topic...quake how many feet of piping did u use on your exhaust
92nsx;1387567 said:You could try but reving that high I would go with Ferrea duel spring valvetrain. To keep valve float to a min.
Also depends on the lift on the cams you are looking at. I know there is something like you only want to compress the spring something 70-80% IIRC. There is a term for it but I forget.
IJ.;1387845 said:I prefer duals for the peace of mind if I'm going to rev an engine that hard.
quake;1387852 said:i thought you determined it was a problem with friction against another spring?
lift is just .334"suprarich;1387853 said:8k would be nothing for your regrinds on a 83 lb seat pressure 127 lb open spring. And before anyone jumps in and says that is not the seated spec for that spring, it is at our installed height. What is the lift on your cams anyhow? Comp suggest not going any closer to .050 to coil bind.
Edit: And IJ is right. Nothing is safer than duals, but 8k is not out of bounds for that comp spring.
IJ.;1387856 said:No after speaking with 1/2 doz spring manufacturers duals use a slight interference fit between inners and outers as a damper.
As I said in the PM I still think it was more of a xxx time spent above 8000 as there were 4 other springs that had dropped 15psi seat pressure.
suprarich;1387944 said:You have plenty of room.
