Advantage/Disadvantages of moving the radiator to the back?
Status
Not open for further replies.
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
IJ. said:
Major downside would be cutting into the structure of a unitised body shell....
Even if it was just cutting out the red area between the frame rails?
I only plan on removing the floor pan and eventually the car will have a full cage. I think I can make up for removing the floor by adding a bar or two.
Yellow 13
Lurker
Apr 4, 2006
2,308
IJ. said:
Ok assuming you do brace it enough where do you plan on running the coolant lines?
They're going to need to be minimum 20mm id so figure are 25mm od.
Huurrr...To the engine? :biglaugh:
Where are you getting 20mm, the stock hose I measure was only a little more than 8mm across.
Anyways Ill just run them along the passenger side floor up to where the stock heater lines came into the car, drill the whole out, then run them to the engine. Anything wrong with that? :icon_conf
WTF is 8mm?
We are talking about moving the radiator to the back of the car aren't we?
(or am I totally confused)
Yellow 13
Lurker
Apr 4, 2006
2,308
IJ. said:
WTF is 8mm?
vvv
:icon_conf :icon_conf :icon_conf
speed
Gone. Email me.
May 27, 2006
1,045
not here
www.timduganphotography.com
I'll bet you your car it isn't. it *Might* be the thickness of the hose wall, but the hose diameter is NOT 8mm. And IJ, for a 25mm od that'd be a 2.5mm wall thickness- shouldn't he go considerably thicker than that (assuming rubber hose and not braided) especially if he's going to be racing it? Thats a lot of fluid being exposed to a lot of potential damaging items.
I'd be plumbing something like that in hardline not rubber but my point was there is NOWHERE under an a70 chassis to run 2 lines that size.......
Running through the car is totally unacceptable.
Yellow 13
Lurker
Apr 4, 2006
2,308
IJ. said:
Not being a cock or anything but are you challenged in any way?
Yes, and I misread my tape measurer. The total lenth of the tape measurer is 7.5m and has that printed just above where I was reading the diameter. I took it for 7.5mm.
Why so?
They run them inside the car for NASCAR?
americanjebus
Mr. Evergreen
wa.
Hey man i know its bad when IJ starts giving you flack but in all honestly. If you have a shell that is ready to be tested w/ i say go for it. Im just interested in seeing it done.
But i'd address this issue first ^
It may not be the most cost effective move of the century but the things your going to overcome in the process of this project will answer other questions or pave the way for OTHER ideas.
Go for it man, like the guy that made the 240 it shouldnt cost you much. if i remember correctly he was the biggest underdog w/ the smallest budget relying mainly on 2nd hand parts to create that thing.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
TOMA70E said:
Why so?
Based upon what I have read in this thread, you're going to want to keep those lines outside the cabin so when (not if) they blow, you won't be sprayed with 180F coolant.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
TOMA70E said:
Why so?
Denied.
Nascar prohibits engine cooling lines inside the cockpit due the possibility of burns.
Furthermore, you must make the firewall (both front and rear) as solid as possible.
You never want hot liquid inside the car near you. You also do not want fuel lines inside the car with you, unless you are wearing fire resistant clothing at all times.
Try 210 deg.....
Edit, just looked at Dent Sport Garage's website.
All I can say is, YIKES. (Welding and the whole well uh yeah)
Supracentral
12
210 in traffic maybe.
On the road course, realistically about 230. Regardless this is one of the worst ideas I've seen in a long time... The return on investment is minimal, it's functionally inferior and a maintainence and upkeep nightmare, IMO.
But to each his own... Not my ride, not my call.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
lol, sorry guys....either way, I wouldn't want to be sprayed with hot coolant, nor would I want that extra turbulence within the cabin...
Status
