Is there such a thing as having too small an oil cooler? I have one that is twice the size of stock and i'm running the permacool oil relocation kit from summit.
Is it possible to be too small?
Next question:
When i first started the car i popped a hose off my thermostat (b&m oil) had a look and no clamp, assumed i forgot it. Got a clamp and reclamped it and thought everything was fine and dandy till tonight
Noticed my oil pressure was dropping and i could smell oil burning and looked behind and oooh fun, smoke trailing behind LOL.
Shut off car in time (was only cruising at the time)
Have a look where my thermostat is and lo and behold that hose had no hose clamp and and popped off again
I believe the relocation kit uses -8an barb fittings and the hose i got was meant to be for that size. It does not pop off the oil cooler side but it does off the thermostat side.
I have barb fittings on the thermostat and pushlok's & fittings on the oil cooler.
Is there such a thing as crap hose? Are there better hose clamps out there that won't play invisibility tricks on me?
What could be causing it to pop off, this hose has attempted to end my engines life twice (without succeeding i might add hehe).
ps. i went off Ians (IJ) directions for in/out on the thermo and i figure 350km's later i would def know if it was backwards haha
Next question:
