7MGE head on 7MGTE block
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
I ran a GE head in my 86.5 when I did the GTE conversion. No issues whatsoever. This subject has been discussed billions of times. It's only a factor when you have certain power goals. My setup was stock so wasn't concerned.
There really needs to be sticky on this since it's brought up so much. I'd do the write up if only I knew what I was talking about.;)
8,898
Poodles;1163157 said:
More lift for sure (by TSRM spec) the rest of the specs are unknown (conflicting stories don't help)
More lift for the GTE cam.
There was a change in the intake cam on the GE engine. The Cressida had it first, then the Supra. So you may not even get the same results as somebody else, even buying new.
Yeah, supposedly the GE has more duration, but I've heard that it doesn't as well...
Still need someone to take two new cams and have em profiled...
