7m maximum RPM
supra90turbo
shaeff is FTMFW!
32
MA, 01440
It's not the block so much as the head. Gotta get it to flow!
Either way, it's in the build...
Mibrum spins his to 9500 :D
AcIdBuRn02ZTS
227
Indiana
Ive been curious of this myself... what would be a safe limit to spin a lightly modded 7m with a little head work but stock internals/valvetrain?
Stick with the stock rev. limit?
-AcId-
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Bump it to 7k if it has the potential to breathe, but I would do valve springs just as a precaution.
I really wouldn't recommend doing that on an otherwise stock engine though.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
+1 on valve springs, shot peened and x-rayed rods at the minimum. Thats a fair amount of stress and they are already one of the weaker points in the motor.
IBoughtASupra
4,455
Queens, NY
The 7M was never meant to be a high revving engine but if you upgrade the oil system and make sure all the specs are within range, you can do some pretty good stuff.
Um.... no. 6500RPM is high for it's stroke and age. Stock SBC's would be pushing it at 5K and usually are well out of their power band by then.
The main limiter to revs is valvetrain. After that it's the bottom end.
RotaryHead
Gets beat up by Motors
Aug 27, 2009
219
Tucker, Georgia, United States
i was just wonderin i know i need to build the head to handle the high revs but i just wanted to if anyone has had any issue with the blocks comming from rx7s and hondas i like my revs to be in the 7 to 10k range for my driving style
---------- Post added at 08:48 AM ---------- Previous post was at 08:46 AM ----------
i had planned to build a block girdle and do as much to the 7m block to make it reliable as i can at the upper rpm ranges as i can pure sex to here a engine in the upper rev ranges pulling full blast
it might just be me thou but pure sex
