550 cc injector soldering project
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Can any one point me in the direction of the thread or simply answer this question:
Can the wires be "mixed" up on each individual injector plug. Im worried that one is "+" and the other "-" etc etc etc.
Any help?
I know that each set of wires has to go back to its injector. #1 set of wires goes to #1 injector.
DUH.
:wuteva:
Disced
Pie + NYQuil = FTW
Edmonds, Wa
Well; I'll tell you what i did. I didn't match anything up at all. I just soldered each set to the new set and so on. IE: injector wires 1 hook up to new injector wires. They don't matter.
drunk_medic
7Ms are for Cressidas
Woodstock, GA
Whatever you do, make sure and use flux when you solder 'em, then clean the flux off with alcohol and an acid brush when you are done.
Keeps oxygen from combining with the metals when you solder. This prevents any corrosion in this area, which would be a very important area.
shaeff
Kurt is FTMFW x2!!!!
11
Around
and i believe our injectors fire in a series of two at a time... well, at least thats what it looks like upon viewing the wiring schematics in the TSRM.
http://cygnusx1.net/supra/library/Wiring/pages/Page_054.html
so, it looks like you could even mix up injector wires 1 and 2, 3 and 4, 5 and 6 between each pair and still have it fire correctly....
someone please correct me if i'm wrong!
-shaeff
shaeff
11
Around
IJ. said:
My understanding is they batch fire in a sequence to help prevent fuel pulsation (hammering in the rail).
soooo, are you agreeing with me? haha
-shaeff
shaeff
11
Around
oh i know that, i was implying that you could use the
#2 injector wires for injector #1
injector #3 wires for injector #4
and injector #5 wires for injector #6.
does that make sense? its 4:40am here, im tired, and its about bedtime, but i gotsta know! :)
-shaeff
Idealsupra
Orlando
www.tampabaysupras.com
-shaeff
yeah im half agreeing with you also..
as they do fire in pairs...its not 1/2 3/4 etc... they are mated with each specifically...
as for wiring..the sequence cant be messed up... but im pretty sure it doesnt matter which wire goes on which side of the connector...i would just do it up like it is stock..hold the injector as if it was in the rail..match up the clip...and get to soldering in the position the clip is etc....
shaeff
11
Around
ah, i'm no wiring expert, but thats just how it appeared upon looking at the schematic. well, at least i wasnt ALL wrong :) thank you for the correction, i'm off to bed!
IJ. said:
I'm guessing what you mean is I could use either wire for 1 and 6?
that was the jist of my theory, but Ideal has corrected me. i thought they fired 1/2 , 3/4 , and 5/6. i get it now. hmm. kindof makes me wonder how i got all my injectors wired correctly when i did my swap. my harness is pretty haggard, and i just guessed. the car always ran well though...
-shaeff
Jeff Lange
Administrator
4,926
17
Sunnyvale, CA
jefflange.ca
Number 1 and 4 fire together.
Number 2 and 6 fire together.
Number 3 and 5 fire together.
I'm pretty sure you can't get the wiring backwards for each individual injector.
89 Black Beauty
Supra Alarm & Stereo Guy
Jan 11, 2006
Abbotsford
figgie;28655 said:
The injectors are non-polarized. So either pin on the injector could be + or -. It still will open.
so this is the final CORRECT answer? I'm wiring up my PTE 550's.
I hate reading through pages and pages of maybe if and IMHO's.
Thanks all!:icon_bigg
Sil
Evil Empire
Jan 13, 2008
340
Milwaukee/Chicago
I just visualized them up as to the relative position of the injectors and how the clips should go, soldered then shrink wrapped them, I don't think making sure they matched up added that much more time to the process. I like my striped and solid wires all matched to their respective color, but thats just personal preference.
