modmonster2008;1441780 said:theres two knock sensors on my n/a... mines an 88 btw..
Pics or it isn't true
That's because on late style blocks the KS boss is further forward, thus not requiring the starter to be loosened. (and for early blocks, you just have to loosen it, not remove itsparkplug619;1441686 said:lol. Well problem solved, I rewired both connectors, plugged one to the k/s closest to the alt. and plugged the other closest to the starter... without removing the alt or starter like most people say must be done! Too bad I cant test it until I find my damn keys
Not from the factory, there isn't.modmonster2008;1441780 said:theres two knock sensors on my n/a... mines an 88 btw..
quin;1441777 said:all three of mine were threaded on all one of my 87's supras.
FullNelson;1443163 said:ftfm
Quin;1441777 said:All three of mine were threaded on all three of my Supras.
Kevin;1443308 said:oh also i found a thread with a pic of the Knock sensors on the block...
http://www.supramania.com/forums/showthread.php?t=109734
its the first pic in first post..
you can see the two porper knock sensors and you can see wheere people might think there is supposed to be one
sparkplug619;1443324 said:thanks alot, I accidentally added a knock sensor where the yellow circle on the top is at, dumb me. Lesson learned, knock sensors rewired, code 52 still exists, now I need to figure out which is bad.
sparkplug619;1443333 said:lol I have a good knock sensor (the one I added to the middle boss on accident) Ill get it done first thing tomorrow
