Originally i planned on upgrading my 1jz single turbo swap and giving it a little giddy up!!! To do this i had purchased a mint greddy t88d off of a local for a killer price butttt as many of you informed me this was probably not the best turbo for what i was trying to do... getting to the point i decided to bag the whole t88 1jz idea...
First off the T88 is being set aside for my t100 2jz build :icon_bigg....But i decided to go with an holset hx35 with the hx40 kit its fully ported polished and ceramic coated.. Im hoping that i can get the power i want from this turob...
Does anyone have experience with the holset hx40 turbo's on the 1j's??? i Read a few threads about the hx35's but i want something a bit more...
The car made 458 wheel on 93 octane at 20 psi with its current setup but im looking to get at least 100 more HP to the wheel, to do this i planned on upgrading my fuel system once again to 850cc top feed injectors an additional inline walboro 255 pump to support the intank 255 walboro.....
As far as cams go can i see the number i want by using the 2jz cams and having them machined to fit the 1j head? or will i have to go with 264's?
this is what the car has now
Mines racing ECU with all the bells and whistels: Boost cut, Fuel Cut, Speed Cut. 750CC injectors. psi out of a .64 a/r turbo and more.
2jz map sensor
xs power single turbo manifold
3" I.C piping and xs power front mount
In tank walboro 255 w/ slosh tank (adding an inline 255)
New coil packs and ignitor
Full 3" exhaust
Im sure im missing stuff (its kinda late) haha.... but if im missing any key parts please let me know... now i know most of you are gonna say ditch the Mines ECU but i contacted mines and gave them the serial number and i was told that the ECU should eaisly handel 550+ hp... Im hoping that the upgraded cams and turbo should put the car up in the 500 area
Thanks Guys!!
2jz map sensor
Full 3" exhaust
Thanks Guys!!
