I am frustated , three days in front of the computer and I have not idea what tyres will be the righ choice.
I have 245/40r18 toyo R888 at the front and a 265/645 R18 pirelli slick at the front and the slick is biger in height than the toyos but on the Toyo web page say the diameter of the 245/40 is 653 mm !!!!! so how big is the slick?? if on the side say 645 mm how mutch is the diameter really????
I am lost because I am trying to select a set of tyre for the track and set the floor height of 100 mm to the ground and then after the trackday put a set of street tyres which can give me 20 mm more of heighy to rise up the car to a safe height but is really difficult because nobody say the truth on hes tyres.
Like the supra dont have to much room in the wheel arches so if I like to use the flat floor and reading that 100 mm is the minimum height to get downforce I have two ways to get it ,
1 - lowering the overal flat floor till get the desirable height, using some spacers and using an air dam at the front bumper to lower the splitter and then I can use slicks but the slicks have big diameters so to use the Supra o the streets I need so much taller tyres or adjusting the height of the damper.... no way
2 - using a semislicks I can lower the desirable height with lower profiles tyres and small adjuste on the dampers thanks to the small diameter giving more room on the arches and for street, use a normal street tyres with 20 mm bigger diameter.
on the first point the use of slick will need harder springs and special settings...... uhmmmm no way because on the public roads will be a non-viable use. but slicks are slicks , full of grip and lower weight.
on the second point , maybe with the help of the flat floor, lower center of gravity due a lower chassis position and harder sidewall on the tyres .... maybe we can get the same grip of a full slicks eh??? then no need to use an agresive chassis and suspension settings so the use on the public roads wil be viable
what do you think guys, are my reflections correct?
at the moment I ike a lot the posibility of drive my supra any day I want so.... I will have time in the future to radicalice it only for track use with plexi , no window lifters ,no central looking , full stiff suspension and a full welded cage but not now.
