Gurley's 92 Teal 2JZ Project
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
detailed the motor tonight to get it ready for vegas, and finished the clutch.
gurley0916
Mar 10, 2008
1,138
Columbus,OH
Thats my secret :icon_bigg If you cut a 2.5 inch hole in the firewall behind the intake manifold you can run the harness through the dash behind the cluster and into the glove box with out any extending. This works for both 1j and 2j swaps as multiple of my friends have done it. Makes it look so much cleaner. As for the other parts of the body harness I tucked it all under the fenders.
gurley0916
Mar 10, 2008
1,138
Columbus,OH
Went to SILV and dynod the car and it made 340 hp at 11lbs Heres the dyno graph and the video.
[video=youtube;kJ2MPNgXjNQ]http://www.youtube.com/watch?v=kJ2MPNgXjNQ[/video]
IBoughtASupra
4,455
Queens, NY
Nice. Those are some
Good numbers. Still in stock computer and fuel? You can hit 400 easily if you raise the boost and upgrade the fuel. I am not sure but 550's would be enough to run 400 to wheels. I can be corrected.
IBoughtASupra
4,455
Queens, NY
I hope to go down to SILV next year. What was the cost of running on the dyno? Is there a fee to attend because the pictures show that it takes a lot of work to organize it.
gurley0916
Mar 10, 2008
1,138
Columbus,OH
Ya ive spent more than enough of the project for now and im gonna start saving up for fuel and engine management. Im looking into going pro efi for the ems and will do full fuel set up as well. Gonna be a long time though. Im the mean time it will stay they way it is, not doing the piggy back route.
Silv cost 60 for the 2 pulls on the dyno and the other events usually cost a fee besides the scenic drive.
IBoughtASupra
4,455
Queens, NY
O, okay. That is a good deal. Makes 100% sense that you are going to save and do it right. I took apart my 1JZ recently and plan on upgrading to a single but run stock fuel and boost to break in the engine and after that.....EMS and full fuel upgrade...feed and return lines, pumps, injectors and rail.
I am going to put a stock AFPR with the stainless feed and return lines to the stock lines to the tank. When I run the full braided lines too the tank, I am going to put in a fuel filter in as well on the return side.
I am not sure but could you E-Mail me some pictures of the hole you cut in the firewall to route the wiring harness, exactly where to cut. Don't want to make a mistake there. :-/
Albert
May 13, 2009
1,710
Tempe, AZ
gurley0916;1626486 said:
Update time:
Im also working on putting in a competition clutch stage 3 ceramic disc before SILV
Actually its the stage 4: 6-puck sprung ceramic that is in your car.
gurley0916
Mar 10, 2008
1,138
Columbus,OH
It wasnt hard at all I just found an old oven on craigslist and used that to bake the parts. I used powder form eastwood.com and make sure you sand blast the parts first.
gurley0916
Mar 10, 2008
1,138
Columbus,OH
I would just polish them or chrome them because the Powder coating holds in alot of heat to be honest
And yesss BJ91T we could be Brothers...cant wait to see that 1.5 swap your thinking of doing!
IBoughtASupra
4,455
Queens, NY
I have a load of exhaust wrap to wrap my manifold and then the aluminum wrap one to cover the black wrap so it looks shiny and a nice turbo blanket too. :)
whitemike
1,164
Winter Park, Florida, United States
Looking good as usual. I'm about to go 2JZ as well and just have a question.
When cutting the hole behind the intake for the harness.. does the wire harness fit easily without extension or does it just barely make it where it needs to go? Also, is there any chance of you recalling exactly where you cut the hole? Is it visible at all with the engine in place?
Thanks!
Albert
May 13, 2009
1,710
Tempe, AZ
On my 1jz with a Jza70 and a Jzz30 and also with his 2jz , cutting the hole in the firewall (with is just below and a little to the left of the throttle cable hole) allowed us to run the harness behind the cluster and be able to make it to the glovebox without extending the harness at all.
and No you can see it unless youre back there trying to look for it.
Heres a refrence of the hole:
And with the motor in:
