That's a bit of an open question.
A 3" pipe will flow 1200 CFM before it goes "critical" (Mach .4)
At it's critical speed you're heating the Air through friction.
You can convert the 1200 Cfm to lb's/min so around 83.
This gets you into the GT42/104 Compressor size range at a 2.8>3 pressure ratio. (around 30psi)
Keep in mind this is all gumby math on my part and not exactly accurate
So you're looking at 8>900 hp before the 3" TB becomes a restriction, the other side of this is someone installs one of these Monster TB's and the car feels MUCH more responsive/snappier in normal driving so they think WOW what a difference the TB made!
It's a placebo as all that's happening is it flows a shitload more at 5% opening then the old TB did so if they'd used 10% opening on the old TB it'd make the same power.
You need to be making insane amounts of power to utilise the Big TB's on a turbo motor.
