will a 1 ton foldable shop crane (cherry picker) be able to pull out the 7mgte
vIetDrIfTeR
134
d town
is the legs and arms to short to get it out?? or do i have to get a 2 ton shop crane???
please tell me a asap i got a coupon for HFT ( harbor Freakin'it Tools) for 100 dollars thats about to exspire
thanks in advance
SC61 MK3
316
FL
ya used it before was fine, if you're worried you can always pull the tranny before to lighten it up
spencyg
141
Maine, USA
7M-GTE weighs under 700 lbs with the transmission attached, so since 1T = 2000 lbs, and 2000lbs is significanly more than 700 lbs, you should be fine.
Be aware that Harbor Freight totally sucks for anything hydraulic, electrical, or pneumatic.
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
The problem is not so much the lifting cap. but the length of the boom. The one ton versions when the boom is extended all the way
the lifting cap. is 500lbs. and the total lift height is not as great as the 2 ton ver. Short boom will also not reach the center of the
engine compartment with the front bumper on. This is true with both the Harbor Freight ver. and Northern tool. Get the 2 ton.
Devin LeBlanc
1,830
Las Vegas NV.
I had the same problem, I ended up using the boom off a 2 ton hoist on the 1 ton and it worked no problem, I pulled my engine and auto tranny together, worked just fine
northwestsupra
1,166
Washington, Marysville
I have a 1 ton from orileys. The part where you jack hits my bumper making it hard for install. But Its possible with tons of love and a little dancing a swinging lol. But I got a fully assembled engine and tranny installed with it
sent from my ultimate droid
ask92
That guy.
Nov 17, 2008
357
Rocklin, CA
Id say drop the tranny then pull the engine out unless you wanna just buy a 2 ton(that would be the best option)
vIetDrIfTeR
134
d town
yeah exactly what i was scared of...damm but it only 100 dollars do you think it worth it to get it or it wont even work ??? da 2 ton is 200 bucks
---------- Post added at 11:36 PM ---------- Previous post was at 11:33 PM ----------
did u have to special order your 2 ton boom??
---------- Post added at 11:37 PM ---------- Previous post was at 11:36 PM ----------
drop the tranny or just loosen the bolts??
bioskyline
1,236
powell river bc
my shop crane
but 1 ton is a lil small. works great on trucks with the flat front end. with out bumpers lil tricky without removing it for that extra reach.
