So my 7M Supra build of the past two years is just about come to completion, and only a few small bugs remain to be worked out before it's ready to be broken in, and had some miles put on her. My current problem arises when building boost.
The boost controller is turned way down, and I’m only talking about 4-6 lbs of boost here. The engine can build up to 8 when it’s cold but less when it warms up. The turbo begins to spool; the computer dumps a ton of fuel and the engine sputters and gags. The wideband goes off the chart in the rich direction, and it is no longer drivable. The check engine light flashes for a second.
The motor starts, idles and runs beautifully otherwise.
So we’re trying to figure out what the issue could be. Do we have a vacuum leak somewhere? Is the MAF sensor bad? Bad fuel delivery? I know it could be a multitude of things, but I thought I’d seek the help of the 7M community to offer me guidance, and possibly a direction to take to get this issue resolved so we can break in the motor correctly.
Thanks for any help you all can offer.
Craig Batstone
Burlington, Vermont
Craig Batstone
Burlington, Vermont
