D
		drumminforev
Guest
If there is a thread about this, direct me to it because I didnt see it but...
Why is it that 7m's always blow the HG. Even NA motors?
GrimJack said:The stock torque wasn't even enough to stretch the bolts properly, so they could loosen - there's been cases of head bolts that were so loose you could pull them out by hand.
72 foot pounds is perfectly safe on stock head bolts, they are reusable, and a stock head gasket with proper torque will hold 320 hp without any problems.
Ckanderson said:QFT...
I ran 330 hp for days on stock HG
	jake, you're entirely right, and that is why i always blame them for blowing. The walls are waaay too thin to begin with and sadly nothing we can do about it :nono:Reign_Maker said:Geezer, there is a design flaw in the head, and the block, IMO... The water jackets are too close together and teh cylinders are too close together... The other main design flaw is in the HG itself, being essentially pressed wax paper and copper rings... It doesnt take much to push that ring into the paper and right into the water jacket...
To me, yes, heat may play a part, and yes the two metals will expand at different rates, but if they had used a HG that was worth a shit, and torqued the head down to a higher rating and if they had thickened the walls between the piston jackets and water jackets, I dont think you would have near as many BHGs...
	Well does the 7M blow it's gasket between the cylinders?As I know it mosly blows between the water jacket and the cylinderReign_Maker said:![]()
As you can see, there are some major differences in the 7M than the RB... Also, you have to remember, teh RB26 is like the 2JZ to the 7M... But anyway, look mainly at the thickness between the cylinders, and also the size of the water jackets, are much larger... Also, if I remember correctly, dont RB26's come with studs and a mhg? And really, the "problems" with the 7M head/block design can be easily remedied with a proper prep, mhg and arp's torque accordingly... Toyota just effed up, then they recovered with the 1&2JZ motors...
