Why arent we making 1500 HP?
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
I wanna know why us 7M's arent making the power the those high and mighty 2JZ people are. We have essentially the same engine as them, so whats holding us back?
The best 7M setups are pushing what...700-800 HP?
2JZ's are making twice that. Why is the 2JZ so much better at making power over the 7M, theyre both 3.0 liter, 24 Valve, I-6.
Centrelines for the Valve spacing restricts us to +1mm valves, 2JZ are +1.5mm stock and can go even bigger.
You can only flow xxx through xx size valves there's no magic involved.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
You need to make HPF's sell thier mk4 and build a 7M mk3. Plus, the 2jz came later so they realized thier design flaws in the 7m and fixed them with the 2jz. Wait till summer with some of the build threads here...:)
Yellow 13
Lurker
Apr 4, 2006
2,308
Ij, I heard that the 2JZ head could be used on our blocks. Wouldnt this be a solution to that?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
2j head on a 7m ummm the bolt patten is diffent so i can not see that happen
but some peoeple do put 2j vavles in the 7m head so i whould start there
You can tip as much money as you like into a 7M the cold hard facts are that it will only ever flow as much as the largest valves you can squeeze into the space allowed by an 83mm bore....... :3d_frown:
NashMan
Aug 5, 2005
4,940
17
Victoria BC
IJ. said:
2JZ valves that have been cut down .5mm so they fit.
really there was post a wheil back on one of the froms i go to and he got the 1.5 to fit with out re sizeing i wounder what he did or if it was just bs
b005t3d
505
bellevue,nashville, tn
talk to allan(defiant 7m). that man is doing ome crazy work trying to make his na pull air like a turbo. he might be running the 2j valves/ some crazy shit going on inside that head.
Yellow 13
Lurker
Apr 4, 2006
2,308
GrimJack said:
Yup, Mibrum. I don't know what he's done to the head, but he's stone cold crazy.
He needs to make a build thread. I wanna know how hes doing it. His 7MGTE is insane, making that kinda power on stock bore, and the stock head too.
8,897
There isnt a "design flaw". The JZ head was designed for more high rpm operation, as already pointed out. It flows more, end of story.
With displacement the same, the torque can be about the same, but the torque will drop sooner in the 7M than the JZ head.
And yeah, I am not willing to dump $50,000 grand into a car. Or more.
Mibrum/Brian's motor is very close to my motor in spec the differences are the enormous custom almost square cams and the huge induction system needed to supply the motor.
There IS a limit and I don't believe anyone has tipped enough $$$ into either a 7M of a 2JZ yet to find it in either motor but the 2JZ's will be higher due to flow potential.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Nick: I was referring to the massive open water jackets around the cylinders where 90% of our head gaskets fail. I am not familiar with the 2jz, but it sure looks like Toyota addressed this "flaw" when I look at the 2jz head gasket.. :)
No offense meant but when I search for BHG I get like 476 threads here.. :dunno:
