Whitening and/or cleaning coolant overflow bottle / reservior ?
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Anybody have a tip or trick to getting the overflow bottle, brand spanking new and white? I picked up a pretty clean one at a junk yard and want to make it absolutely white as can be. My current bottle is ok, but its not white or new looking. Now I have one I can take my time with off the car. ;)
Any solvent that works well? I've tried plain water, water with a little bleach and no change was apparent. I dont want to ruin the sensor, but I would love the bottle to be shining white!
Thanks!
-Andy
Koenigturbo
1,336
Oxnard CA
I was wondering the same for myself, but only my problem is worse. I have black, soft, gooey stuff in the bottle, I wonder what that is.:3d_frown:
You can get it pretty clean, but the yellowing is age/heat/UV and the only way to fix it is to replace it in my experience...
gofastgeorge
944
Texas
After buying a car with a BHG, I cleaned the junk out of it with strait Simple Green cleaner, and a few marbles.
After putting a few ounces in, and the marbles, I shook the crap out of it.
(pun intended)
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
ultrasonic cleaning bath with industrial detergent cleaner (Alconox) is the only thing that got mine clean.
martin p
1JZ-GTE powered Supra.
Feb 5, 2006
215
East coast. UK
Bleach it I did it doesn't make it 100% but it works well. just fill it with thick bleach and leave overnight. then rinse well. and repeat if required.
gaboonviper85
3,236
Northeast Philly
Qft!! Use the ultrasonic machines with alconox also here at work too clean supra parts....gets it as clean as possible!
gelboy1015
Vroom Vroom!
Jan 1, 2007
234
Houston, TX
I sprayed the inside of mine with purple power and let it sit for a couple minutes. Used a green "scratch pad" type of thing to scrub the outside. Looked fairly good.
streetracer_258
Powertrain Engineer
Sep 1, 2009
26
Nottingham
The best thing i've found is to put a load of rice in and some soapy water and then shake it. The hard rice is quite sharp and gets into all the corners nicly. I used this method on a car which had a BHG and it got all the oil out.
emiliorescigno
1,199
Woodbury, MN
I don't know if it works, but I had to post the picture.
limequat
Dissident
Detroit
^ truth. Cheap plastic distorts and changes color with age.
Need a white bottle?
Step 1: Remove 7M
Step 2: Install decent engine
Step 3: Install new bottle
