Where can I buy a Car side stereo harness?
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
My MR2 Harness is fucked up. Its weird for a Toyota radio, but its a single plug, rather than the normal Toyota 2.
Is that a junkyard item or does anyone know if I can find a ready to solder one at like circuit city or what not?
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
Sounds like it has an external amp, so it's got a different connector, but it should have the 2 connectors somewhere else in the dash there. If you're trying to use an aftermarket stereo that is.
If you want to use the factory stereo, it's junkyard diving time.
Jeff
EDIT: It's an 87 MR2 right? I've never seen one with an external amp or non-standard connectors... :confused:
Big Wang Bandit
Feb 21, 2006
7,551
I want to use the Alpine deck I had in my Supra.
The current harness is hacked and butt connected, whilist still using a a toyota headunit.
Are you saying I should keep digging in there, maybe finding something more Jeff?
Justin
Speakers?
Spokane, Wa
Jeff
I concur with what Jeff is saying. If it only has/had a single plug then its going to be an amplified system. <86 had two plugs, although they differed from the <87 in size. To my knowledge toyota has always used two plugs for non amplified systems.
Any chance you could get a picture of it? Chances are one of us can idenfity what you're working with by sight...
Also some information that may help.
Many times when Toyota uses an external amp they will have the 'normal' harness plugged into the amp as well. Metra part number 70-1761.
The harness from the radio will obviously feed the signal to the amp. The output from the amp is the 1761 harness. In order to bypass the amp you just unplug the harness and plug it into your metra harness. Easy Cheezy :)
Not sure if that was helpfull or confusing :)
Big Wang Bandit
Feb 21, 2006
7,551
lol, it has a metal button
Justin
Speakers?
Spokane, Wa
Do the rear speakers appear to be factory?
What I am getting at is that very much appears to be a 70-1398 harness ( Metra part number )
The front speakers, ground, and switched power are in that harness. The rear speakers and constant power are in a second, smaller harness that you appear to be missing.
What color is the wire that is all by itself that you took a picture of? with the female spade connector on it?
Big Wang Bandit
Feb 21, 2006
7,551
purple and brown I tihnk.
Here is from MR2OC
Those are the stock connectors for the 85/86 radios. The 85/86 did not have rear speakers, so they came with a connector with a single wire that supplies +12V from the 10A HAZ-RADIO fuse. This is an uninterrupted supply of +12V to your radio so that you don't lose your presets."
Justin
Speakers?
Spokane, Wa
Here is from MR2OC
Yeup, that's exactly what I was thinking
Big Wang Bandit;1054812 said:
I'm going to the yard tomorrow I think.
What i'm getting at is... Can I cut the harness from an 87+ toyota and will it adapt?
Sure, you could cut a harness out of a Honda and make it adapt.
just have to make sure the colors are correct and you can use any harness you desire :)
