Whats your fastest highway mph ??
TealMetallicDream
Team Dragst@ Member
Jan 3, 2006
105
Detroit
Down but not out;1121224 said:
Come on Duane your car must have the power to hit 200mph DOOOOOOOOOOOOOOOOOOOOOOOOOOOOO IT
Just because a car has the power and gearing to go 200mph dose not mean it has the structural aerodynamics and stability to get there safely. I wouldnt do it in a MKIII supra unless i knew that thing had no lift on it at high speeds. My personal best was 155-160 area racing a c6 z06. Melted two pistons when i did it too :icon_bigg
They do as been proven the past few years in Europe with MKIII's taking the stop spot at the events...
There's a thread somewhere, but the cars are capable of handling the forces.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Poodles;1064636 said:
Pretty much stock everything but a shimmed wastegate. Test track of course...
Many more mods now, and it gets going so much faster I'm a bit scared to do it again...
At least he was on a test track, endangering people on the highway was fun when i was 16, it's just not worth my time anymore, if I do speed i do it in no traffic and I am wise enough when to and not to.
IJ.;1121704 said:
Don't think I'd try for 200 without a LOT of racer tape on the front panel gaps.
They have pics of it on here (or SF) somewhere, the gap between the header panel and the front bumper gets a bit big and both cars lost the top moulding around the windshield...
It's even more scary to watch the MKIV's with the euro hoodscoops go that fast, the hood bulges noticably...
The bumpers for the drivers side window on mine need adjusting as it moves around a LOT over 150 so that's been my limiting factor.
Might tape the screen molding as well thanks!
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
The main focus of these Mkiii's is the aero dynamics. I personally have been to 141, I am not bragging because again that is not to fast when you talk about high speed. I did test the steering at that speed and the car didn't lift and changed lanes swiftly. if you are someone that likes 150+ I would advise you get a wing and maybe even front canards for your front bumper. The car is quite heavy, but a nice gust of wind under that car can call for disaster.
Another important thing is also keeping your engine at a good operating condition. Those HIGH RPMS are not good on stock internals and I have heard of a few people hurting their engines. So the right oil and parts are also crucial.
By "covered" I mean ;)
Brand new GTE block
7M Niterided Lightened Crank
+40 thou Triple coated JE Forged Pistons
Pauter Rods
ARP Main studs
New GTE pump
GrpA Magnesium Pan
Canton Remote Filter adaptor
Canton Remote Filter mount
HKS Stopper 2 mm MHG
NDC Rod Bearings
NDC Main Bearings
B&M Oil cooler
B&M T Stat
Moroso 3Qt ACCUSUMP
ATI Super Damper
Aluminium engine pullies
Wade Cams .351"/9mm lift
280 degrees duration 226 @ 50thou
+1mm Ferrea Valves
Ferrea Valve Springs
Ferrea Titanium Valve Spring Retainers
Ferrea Valve Seat Locators
Shimless buckets
Brand new ported head
2 x Aeromotive Tsunami pumps
Aeromotive AFPR
2 x Bosch MS filters
2 x -6 fuel lines
1000cc RC p&h Injectors
115 litre "IJ" tank
AEM cam gears
Gates Timing Belt
ARP head studs
T04z 800hp roller turbo
Tial v44 WG
3.0" Aluminium Hardpipes
Turbosmart 32mm Bov's x 2
600x300x100 air to air IC
PWR Radiator
DC Electric water pump
321 Stainless Ceramic coated Header
New design "IJ" FFI intake manifold
IJ DBW 68mm TB
3.5" Mandrel bend Dump pipe
3.5" Metal Cat
2 x 2.5" Mandrel bend Stainless pipes
2 x 2.5" Stainless Mufflers
1 x IJ Muffler
Bosch coils x6
2x M&W 3 channel ignitors
MoTeC ECU
MoTeC DBW4
MoTeC 2 axis G sensor
MoTeC EGT
MoTeC wb02
NGK PowerDex wb02
55watt 5000k HID lights
Built a340e
PCS Trans controller
2800 rpm Histall
B&M Fan cooler
DCraig cooler
Strange Nodular Iron 9" case
3.5:1 Motive Gears
3.5 Trutrac 9" Diff
Custom IJ 9" housing
Custom Axles
GroupA V8 CV joints
Custom Stub axles
Diff cooler and pump
Full Strange Engineering Driveshaft
Mk4 TT DBA Rotors F&R
AP Racing 4 piston callipers
SS Goodridge lines
Koni Yellow Coilovers
Eibach Springs
Whiteline Swaybars
Full Poly Urethane bushes
SS Lower Control arms
18" x 9" HR109 rims f&r
265/35/18 452 Falken tires front
285/35/18 452 Falken tires rear
LOL just a little John :D
Can't find the thread, I can't find it on here and SF doesn't have a search feature and doesn't work for me half the time...
TealMetallicDream
Team Dragst@ Member
Jan 3, 2006
105
Detroit
forgot about that, i saw that video. The guy was wearing headphones so he could hear spark knock i believe.
