what's this thing?
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
what's this thing, i kind of looks like the oil pressure sensor that i got with my gauge. it cant be that easy can it?
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
no no, i got the whole car dissasembled. im in the middle of a bhg job.
on the sticker of the new sender it says Thread size: 1/8"-27NPT
Idealsupra
Orlando
www.tampabaysupras.com
no your gauge wont work off the stock sender (at least probably not) as they probably run a different scale of resistances.
its simple just go get an adaptor from a hardware store or pipe place.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
ok so when i go to the store with the fittings i tell them i need a "1/8th BSP -28 tpi :to: 1/8" -27npt" is that the right way to say it? this is probably gonna be hard to find
You need 1/8 bsp male to 1/8 npt female adaptor.
As I said you can interchange them it's not ideal but it does work as it's only 1 tpi and 5 degree angle difference just be sure to use tape on the fitting.
