ok, im looking into buying another supra. its a 87 turbo auto. so, whats diffrent? anything on the wiring harness? ecu? id like to have a idea before i go look some more.
boost fiend said:then maybe m 89 7m is a mut?
all the codes match. as far as i have seen. im not trying to doubt anyone here. just trying to double check.
EDIT: i think you guys are trying to tell me that the 7m had the 6m crank through 89, right? if so, about when was the change over (build dates?)
shaeff said:not all the round-mount 7mgte's came with the 7m crank. mine sure didn't.
-shaeff
daledoe said:89 in an comfussing year.
Superjustin13 said:7m is just more balanced on Cylinder # 2 and 5
hence why redline 6250 instead of 6,500
wtf who dosnt know this
SupraChrisMk3 said:If it is more balanced why would the redline drop, wouldn't you expect it to increase with the better balance?
