some one help me cause on my car this sensor is cut up and my a/c fans doesnot work and this might be the problem...Thanks
turbo4toy said:I'm going with coolant temp sensor...............anyone else?
johnathan1 said:what symptoms would a damaged ecu temp sensor display? (no signal)
Will the A/C work if the A/C fan switch sensor isn't connected
ding ding ding we have a winner. Want to get those fans to run all the time when the key is in the on position? Ground that wire to your chassis somewhere :naughty:CRE said:A/C fan switch
IJ. said:Have a look at the TRSM "AC-9" onwards gives a good description of the operation!
I'm running a standalone ECU so don't have any ECU Hookups at all and the only "features" I seem to have lost are Idle Up and the Econ button.
