what is this sensor called?
SupraManiac
67
P.A. Texas
some one help me cause on my car this sensor is cut up and my a/c fans doesnot work and this might be the problem...Thanks
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
No temp signal to the ECU would probably make it run rich and ilde high... As for the A/C I have no idea. Did you get my PM, Johnathan1?
SupraManiac
67
P.A. Texas
johnathan1 said:
what symptoms would a damaged ecu temp sensor display? (no signal)
Will the A/C work if the A/C fan switch sensor isn't connected
thanks....no wonder my a/c compressor and my fans dont work...cause of the sensors...
NJsupraA70
Ex-Supra Owner
Sep 18, 2005
276
NJ
Thats my diagram. :)
N
NDBoost
Guest
CRE said:
A/C fan switch
ding ding ding we have a winner. Want to get those fans to run all the time when the key is in the on position? Ground that wire to your chassis somewhere :naughty:
SupraManiac
67
P.A. Texas
so you are saying that if this wire is not connected my a/c wont turn on? is this right?
N
NDBoost
Guest
^your incorrect all that is for is when the AC kicks in the fan turns on so no.
Have a look at the TRSM "AC-9" onwards gives a good description of the operation!
I'm running a standalone ECU so don't have any ECU Hookups at all and the only "features" I seem to have lost are Idle Up and the Econ button.
figgie
Twin Cities, Minnesot-ah
that because you didn't input the A/C on from the A/C ecu to the wolf Ian ;)
LOL only cos it easily cooks the AC Amplifier if you get it even a little wrong ;)!
I wired up some relays to shut is off at idle as the cams don't make enough torque to make it happy.
