What does your R154 used fluid look like, shavings?
BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
I dumped my tranny fluid after 3000 miles and making decent power. And it looked like silver metallic paint
The shavings are not magnetic. I wanted to see what your fluid looks like, I'm trying to see if a shop can analyze a sample.
Sent From My HTC One S using Tapatalk 2
Sside
554
Houston
destrux
1,183
10
PA
Not normal. You either have some extreme gear wear, a bad bearing, or thrust washer problem. This assumes you're running the proper fluid.
Redline MT90 works good, some people with very high power or a worn out box use Redline Shockproof, but the box will need to warm up to shift well.
I run a 50/50 mix of Mobil 1 75W-90 and Amsoil Severe Gear 190wt in my W58 (yeah not an R154 but I run 400+hp through it, it's weaker, and I still don't see any metal flake like you have).
Some ultra fine bronze/brass metallic stuff in the fluid is normal, that's from syncronizer wear.
BoostMonger
Sep 5, 2011
880
Shadows of Utah
Thank you Sside :(
And yes I am running mt90, same as PO. it's all silver flakes no copper or bronze what so ever.
It shifts like butter, stays in gear and everything. I don't thrash the tranny and only get on it during the weekends, I only DD it 10 miles a day. I'm going to flush it out to prevent the flakes from getting in a bearing the best I can. Looks like a MC tranny will be soon.
Sep 19, 2011
510
Des Moines, IA
Only had some flakes in my trans when my thrust washer went out, destroyed the bearing in front of it, and my first to second gear shift fork was pretty beat.
But I have never seen a trans that I have drained look like that. I would imagine you will need a new one or a rebuild pretty quickly.
shipkiller
398
Quebec
exactly what happened to mine when the thrust washer failed.
but the shaving seized the hubs bearing onto the input shaft on top of that
Only metals I can think of in there are steel, bronze, and aluminum. Looks like it might be aluminum, which is shift forks...
BoostMonger
Sep 5, 2011
880
Shadows of Utah
How can this happen? Something misaligned?
