What does the BVSV do?
oldsking
789
Chapel Hill, NC
Well both the tips are broken on mine so I have no vacuum hoses on it but the car runs pretty good.... What is the purpose since it's on top of the thermostat housing? Is there something not being done right on my car now?
I have a 7mge
Ummm...you need a charcoal canister. The check valve inside maintains positive pressure in the gas tank to prevent FP cavitation. Plus, you really do not want gas fumes in your engine bay ;)
If your BVSV is broken, you can connect the 2 lines as a temporary fix...you still need to replace it.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Very strange picture in the EPC. In you go back through the NATO version for 89+ it shows a different routing, but it still doesn't look quite right. Odd.
Here is the correct location shown in an old photo from my bhg days:
On the very right side of the pic you can see the BSVS. One side goes to the charcoal canister(left), the other to the throttle body to pull vacuum.
mirage83
457
Georgia
jetjock;1302552 said:
Yep. Why would ported vacuum be connected back into the manifold? Thought I was losing it there for a minute...
Oh well, that's what I get for relying on a Toyota diagram. Think we can get a group rate on amended TSRM's? Or better yet, perhaps a $$$ credit on future OEM parts for you and JDub pointing out their mistake? :biglaugh:
SupraRon
595
Canada
A little off topic and I've been meaning to ask, but if I'm smelling gas fumes around the charcoal canister does it mean it is not working?
Steely;1302927 said:
i didn't remove the charcoil can someone else did and put a vented gas cap
If that's the case, I'd be looking for replacements for both if I were you ;)
FYI - a JDM Supra canister can be easily tucked away under the passenger wheel well.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Not all A70's had a charcoal canister. in all countries, and in Japan they didn't use a BVSV. Some countries had a check valve of some sort with some hoses, but no canister.
Does anyone have the diagrams/description for the Japanese and/or European evap systems? Just curious, as I'd like to see their setup and explanations.
Jeff
Yep...I've seen the motors without the BVSV. The line goes straight from the CC to the TB fitting. I assumed the BVSV was on US cars to meet US emissions (car warmed up 1st before vapor is purged from the CC)...could be a bad assumption.
Never seen car from the factory without the CC.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Yeah neither have I, just seen the diagram for it in the EPC.
On my 4A-GZE (J-spec 91 model) I don't have anywhere I can put a BVSV onto it, so I need to know if I should just attach vacuum to the Charcoal Canister, or if I need to do something else. I can't find any J-spec information for the GZE, so I thought I'd check out a JDM 7M setup, if someone has a pic, I'd appreciate it.
Jeff
