Silver MK3
1,517
Madison, AL
Did you get the steering bushings off of ebay? They look like the same ones I got, and they have been going fine for about a year now.
Yes, ATF is automatic transmission fluid. Here's the thread a made on mine when I added the filter. http://www.supramania.com/forums/showthread.php?182119-Mobil-1-ATF-in-Power-Steering/page2
You are going to need alot of brake cleaner to clean out the reservoir and screen. The stuff was really caked on there in mine.
drogon
249
Dallas Texas
Thanks! Yea I did, that's good to hear, yea I figured it would be lol good thing there is a limitless supply of break fluid here
Silver MK3
1,517
Madison, AL
No not brake fluid, brake cleaner. I wouldn't put brake fluid in there.
Silver MK3
1,517
Madison, AL
drogon;1993308 said:
That's what I meant, my dad doesn't want to use ATF so I'm making him read your thread lol
Haha, you are definitely supposed to use ATF, like Backlash said, it says Dexron on the cap.
bluebullet89
192
Meridian, ID
BabylonDown;1992807 said:
Ever thought of masking off the backup lights to keep the white for contrast or do you think you would prefer the way you have them now?
Ya i've thought about it but i like this look. only difference i would make would be a bit lighter. that, and throwing in LEDS in all the sockets.
Doat
2,599
Houston, TX
Well this morning my MK3 decided to go ape shit when I tried remote starting it then it would not start at all, got it jumped and left it hooked up for 5 min and it struggled to turn over but managed to drive it to an auto parts store to change the battery and that did not solve the power from shutting off when turning the key. Towed her home then went to town on cleaning the cables at the terminals first hoping that would solve the problem and sure enough she fired right up.
Janch
271
Riga
And now u have new extra battery lol
Cleaning and checking is the first thing you do not buying new stuff ;)
Doat
2,599
Houston, TX
ahahah well the battery is like 4 years old and dented also from walmart. I don't mind pampering the poopra, so a new battery will only help but yea I did jump the gun.
Doat
2,599
Houston, TX
I also wanted to do it anyway I mean it's a 4 year old walmart battery only reason I didn't get an optima is because they didn't have it in stock lol.
Backlash2032
1,823
Nebraska
Ugh. So I installed my new cps and plug wires yesterday.. now I have spark blow out. On stock turbo. And 10 pounds...
Sent from my HTC6435LVW using Tapatalk
Backlash2032
1,823
Nebraska
I can do a full pull at half throttle, boost at about 5-6 psi.. and when I go full throttle 10 psi it stutters and sounds like I'm hitting anti lag.. without the flames lol
Sep 19, 2011
510
Des Moines, IA
Did you check plug gap? if so what is it set to? doesn't make much sense to me if it ran fine before. Maybe you need to swap CPS's back out, or retime the cps.
Did you get the cps in right? and did you use a timing light to adjust it after it was in?
Backlash2032
1,823
Nebraska
Plug gap is at .028, and timing is set to 10* btdc, te1 and e1 jumped
The only thing I can think of is if the wires are corroded on the inside and have too much resistance, or they are shorting to ground somewhere
