ok, lol sorry. I got the perfect setup, and I'm going to be serious since I was so rude to an obviously needing and possibly handicapped tuner. Get the oil cooler and the intercooler and remove them, the intercooler is way too heavy and the oil cooler actually makes the engine run hotter since it blocks off 22% of the radiator. This will lower your operating temp and save almost 45 pounds of useless weight. remove the piping too and reroute it directly to the 3000 pipe so that the distance to the throttle body is shorter without all that heavy ineffecient piping and halfass facotry intercooler, you'll make almost 9 whp more without it.
Then ya need to take the vaccum line going to the BOV and hook it up to the wastegate, leave the BOV disconnected. The vaccum source actually allows boost to leak, whereas this method does not. Also burn out the gas tank until you have only about a gallon left, then refill the tank with 87 octane and between 5 and 8 cans of "seafoam" (they sell it at hardware stores) this will actually turn the 87 octance into almost 114 octane, you can't do this with 89 or 91 or 93 because it'll increase the rating too much and you won't even fire the car up.
Another power adder that is cheap as hell would be to take a simple saw zaw and cut the facotry DP before the cat, this open exhaust is not dangerours, loud or illegal and when I did it I had a 38 whp gain with no other mods, it was well worth the saw zaw blade I dulled out when I cut it.
If you are worried about the fact you've disconnected the intercooler, just take some dry ice and pack it around your intake, since you'll do that it will be safe to remove the air filter, this allows the cooler air from the dry ice to enter the turbo and air system and cool it better than even a 4 row FMIC could dream of.
Good luck and sorry for my rude comment, these methods are cheap, effective, and reliable. Try them out and post up pics when ya do.
Sorry bro,
     Will
