I haven't been able to find much information on the Brian Crower stage 2 cams. What are the increases in power or torque? Have you noticed anything different after installing yours?
surferofthesnow;927952 said:I haven't been able to find much information on the Brian Crower stage 2 cams. What are the increases in power or torque? Have you noticed anything different after installing yours?
Ma70.Ent said:Search is very simple, but some people don't know how to use it or pretend like they don't, so now there's no reason for you not to use Search.
The Search button is VERY useful here. You can find a lot of information by using it instead of browsing through pages. If you want to find it, look towards the red circle in this image I've provided:
By clicking on that search, you can type in whatever you want into that search box and get a lot of information. To make finding the information you want easier, click on "Advanced Search" which is in blue text.
Once you have that open, the following screen will appear:
Type the most relevant text into the "Key Word(s)" box. Choose if you want the search engine to look at "Entire Posts", or just for the Key Word(s) in the Topic Title with "Titles Only".
If you're looking for information from a certain member you believe to be knowledgeable, then in the box to the right of "Key Word(s)" type in the user name of the user you want to see information from. By picking "Find Posts by User" you will look throughout that user's whole posting history for the information, while if you choose "Find Threads Started by User" you will only look in the topic titles of that user's posting history.
If you believe that one of our specific sections will have the information you're looking for, then look towards the right where it says "Search in Forum(s)". The default is "Search Open Forums", which means search every single section of this site for the Key Word(s). When saying that you are "Also search in child forums", it refers to the sub-forums that you can go to if you click on the original section. Usually you should leave this on.
Most of the other search boxes under the "Key Word(s)" section are pretty obvious. You can specify the number of a replies the thread should have had (whether you want it to be a thread with a thorough long debate/discussion or a short thread), you can specify the date the posts were made and whether you want to view posts newer or older than that certain time, and with Thread Prefixes, depending on the section, if you specify the Thread Prefix, you can specify your search even further within a forum. For example, the 7MGE N/A section has 3 Thread Prefixes (Mod/Maint/Other), and by picking one of those along with all of the options above, you can definitely find some specific information. Some sections do not have thread prefixes, and some do. Also, you can sort the results in a vast amount of ways. Finally, you can decide whether you want to display the results as Threads/Topics, or Posts.
After you finally go through the above, you will see a page like this. I typed in "Intake" without touching any of the options discussed above, and this is what I got:
Now you can click on any of these topics, and the depending on what you put, the word "intake" will be highlighted in red, because that is what you searched for.
Good luck using the search engine. If you use it well, you won't make people angry
Here are a list of short/common words that you might not be able to search for:
http://www.supramania.com/forums/showthread.php?t=7578
ForcedTorque;927970 said:OUCH!
The guys first post, and his first reply is SEARCH, by the King of Search.
In all seriousness, that search thread has been very helpful to me already. I've never really used the advanced search before. I guess that's because I just a retarded kind of guy.
surferofthesnow;928476 said:Wow ma70! I already tried that. I was starting a new thread to find results from other people who have installed them already.
AJ'S 88NA;929614 said:And I'll stick with my hard weld regrinds.![]()
Around $600.Ma70.Ent;929693 said:How much did they cost you? I'm guessing under 400?
Ma70.Ent;929701 said:Ouch![]()
BLACKCAT;930387 said:Measured the BC 264 cams:
Intake:
Journals: 26.96mm .92 .90 .92 .93 .91 .92
Lobes: 39.20 .22 .21 .22 .21 .19 .21 .19 .20 .19 .21 .19
Exhaust:
Journals: 26.98 .93 .93 .92 .93 .92 .92
Lobes: 39.22 .22 .23 .23 .22 .21 .20 .20 .20 .20 .19 .19.
