What bare minimum wires are needed to start?
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Just want to know what wires are needed to just get her started. I have a 91 supra turbo with a soarer 1jz in it. I'll worry about the rest of the wires after she is purring. Thanks
tsuper92
supra addict
Apr 7, 2005
1,376
mass
you can hook up the big square grey plug(b1) under the dash.it should plug into your stock harness.i think the only wire's that need to be removed from the 1j plug side of this plug is for pps on your year.this plug goes to the ignition switch,fuel pump control and starter.you will also need to hook up the efi and alternator wire's to the main fuse box under the hood
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Thanks for the reply. I should hopefully have it started today then. Also, is there anything else I need to do because the engine that I bought was an auto and it's now a 5 speed and going into a car that's setup for a 5 speed. Thanks.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
if you have the auto ecu and harness,you'll have to jump the safety switch.just make sure it's in neutral,so you don't have to paint your bumper:)
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Where is the safety switch, and how many wires is it for the EFI?
suprahooked said:
Did you put a input shaft bearing ing the rear end of the crank?You need one for manual transmission
Sure did. Thanks.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
the plug that come's off the 1jz harness and plug's into the main fuse box(under hood)is called the ea2.you will need to wire pin1 black/yellow,pin2 black/orange,pin5 black/red to the c1 plug(gray 6 pin) that come's off your fuse box.the c1 plug has the same color wire's,just match them up.
now the ea2 plug also carries the alternator wire's(3 of them) which will have to go to the fuse box also(pin10 yellow/green,pin11 white,pin12black/yellow).if you purchased a clip you should have the other side of the ea2 plug that goes into the jza70 fuse box.you could graft this plug into the fuse box connecting the efi wire's and the alternator wire's into it.you can also just splice the wire's in
c1 plug pin1 black/yellow,pin2 black orange,pin4 black/red
the neutral safety switch wire is on a 3 wire round plug that plug's into the auto tran's.i think you just need to twist the two black/white wire's together.i'm still auto,so i can't confirm this.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
2kV6 said:
Awesome, I will give that a try tomorrow. I'm anxious to hear this thing run. I appreciate it.
good luck.i almost shit myself when mine fired right up first shot.it was so straight forward i didn't expect it to fire up,let alone have no code's
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
I forgot to say that I have the soarer 1JZ. So, I only pray to have as much luck as you. I will check out the colors of the wires to see if they are close or even the same. I've been looking at a lot of wiring diagrams and my brain is fried.
