Just want to know what wires are needed to just get her started.  I have a 91 supra turbo with a soarer 1jz in it.  I'll worry about the rest of the wires after she is purring.  Thanks
			tsuper92 said:if you have the auto ecu and harness,you'll have to jump the safety switch.just make sure it's in neutral,so you don't have to paint your bumper
suprahooked said:Did you put a input shaft bearing ing the rear end of the crank?You need one for manual transmission
the plug that come's off the 1jz harness and plug's into the main fuse box(under hood)is called the ea2.you will need to wire pin1 black/yellow,pin2 black/orange,pin5 black/red to the c1 plug(gray 6 pin) that come's off your fuse box.the c1 plug has the same color wire's,just match them up.2kV6 said:Where is the safety switch, and how many wires is it for the EFI?
good luck.i almost shit myself when mine fired right up first shot.it was so straight forward i didn't expect it to fire up,let alone have no code's2kV6 said:Awesome, I will give that a try tomorrow. I'm anxious to hear this thing run. I appreciate it.
tsuper92 said:good luck.i almost shit myself when mine fired right up first shot.it was so straight forward i didn't expect it to fire up,let alone have no code's
