ok, so today on the way home im getting ready to spool the turbo up(recent hg replacment!! just hit 600 miles. figured id give it a couple of psi.) and i get this horrable shudder and jerking. at first i thought my clutch was shot again! but it moved and shifted fine. then i noticed that if i was on the gas just enough to keep it moving it went away.
anyhow, i pull over and start to look under the car to find that theres only the bottom 2 bolts holding the diff unit in place. F*#K!!!!!!!!!!!!
so i get it babyed home and inspedt farther. the front 2 bolt holes had ripped free from the sub frame. the 2 bolts at the top of the diff had broke free. and the driver side of the lower 2 diff bolts at the rear had cracked the subframe slightly.
long story short, im looking for ideas on hoe to weld the rear sub frame to make it a lil stronger. i dont want to sell the car, but im on a time frame and cash is also short, and its my only car at the moment. any help is welcome.
