Wat the hell!! Why??
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
U get one thing fixed something else stops working !!!
THere this loud squeeling noise i dunno if it's the alternator i dont think it's a belt....i just finish wiring that little rad. fan in front of the rad. with a in cabin switch since i dont have the sensor for it on the thermo. housing correct me if wrong about all of this!
i also added high temp silicon hoses to the MBC and BoV i dunno why if at all this would make my BOv sound different since right now it sounds kinda off i check to see if it's leakin but no... it's a TURBo XS BOV/MBC
So basically this whinining squeeling noise and my BOV sounding abnorma [[[CCcchh]] is the sound
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
While the car is on put a little water on the belt and see if the noise goes away. If it does, the belt needs to be changed. If it doesn't I'd get a mechanics stethoscope and start from there.
Water should make it worse...
Also, you'd be pulling more amps, so higher load on alternator = harder to turn and slipping belt.
Silicone hoses on the BOV and MBC, make sure you ziptie the ends so they don't leak.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
i think since he got new hoses, its probably larger, so its getting a better 'connection' to the intake manifold, which is why it sounds different... but yeah i would double check to make sure all of the lines are sealed.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
As usual Poodles is right on target.
How is a bigger signal line to the BOV going to affect its sound? I would love to hear the logic behind this comment.
shaeff
Kurt is FTMFW x2!!!!
11
Around
cchhchchchch to me, sounds like compressor surge...
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
That assumes it wasnt opening properly before the hose change, in which case a larger diameter hose is irrelevant. A BOV doesnt read volume it reads pressure. Either way, changing the hose could only possibly affect when a BOV opens, not how it sounds...at least not any way I can imagine.
A leak is FAR more likely.
agreed. sound like the BOV isnt opening AT ALL. I suspect some zip ties will solve the problem (or the lines are routed wrong altogether)
noel
Uchiha Member
May 5, 2008
512
LOl it was something so stupid and small the BOv and everything was fine there is a hose that comes out of the intake that hose was pinch cuz it was really soft which made the squelling whining noise
cuz little air was being sucked out once i change that the BOV sounded BEtter and the noise went away! :=-) thanxz for ur help tho guys!.....no i gtg buy a new rad. mines has a whole :-(!!!! Fu** sh** there's always something!!!
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Once again the poodleman called it.
