Vixen's car is cursed..............
Her car has caused me nothing but grief. I've treated it like family and it laughs at me when my back is turned.................:p
Her car cranks when it wants to, and now it doesn't want to. It hasn't cranked in about three days now. The dash lights come on, and you get the bells and whistles, but no starter. I'm sure it's in the alarm, but I feel I've tried everything. I've locked and unlocked the car a thousand times(maybe a hundred). I read the thread by Shaeff in the informative links. I tied the two wires together under the hood by the latch. I unplugged the box that I think is the alarm under the dash and then grounded the blue wire with the orange stripe. I don't know what else to try. I think I'm fixing to go to the service station and buy eight dollars worth of gas and burn it to the ground. (I did some calculations and apparently eight dollars worth of gas is the correct ammount to get the fire going pretty good) If you have any suggestions about where to pour the gas or how to fix this problem please post away..................:1zhelp:
I don't want it to look like this.................:evil5:
Jay: There's a plug down by the starter that has the wiring for the Auto Neutral Safty Switch that in Manual car has a bypass plug check this as mine gave me problems with corroded wires and dud insulation!
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
wet a piece of cloth in gas(make sure its a long piece) shove it down in to the gas tank so that the end sticks out cover car in gas light cloth run like fuck
Edit: i should explain that im a military engineer and for my engineering course we had to find a way to blow up a car useing house hold items one of the other teams try this with very satisfing results and that im not a pyro or crazy... well not a pyro anyway
Thanks guys. I will try some of your suggestions tomorrow................:biglaugh:
I'll let you know which ones I tried after the initial investigation by Sumitons finest.......................:naughty:
Yblegal91t said:
bury it and see if it rises back out from teh ground
There's no doubt in my mind that it would. It would do it just so I would spend more money on it. The motor is perfect, the car has no rattles, the paint is new, the tires are new, the wheels are new. It's still not content with all of that. It finds a new way to piss me off everytime I fix something else..........................:dunno:
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
I feel your pain SH, I really truely do. Ive finally had a full week of driving Lucy without some problem or another. They can just be biotches sometimes!
If cleaning the starter signal connection doesnt work, your gonna want to see if the wire is sending a signal in the "start" position. Just test it with a voltmeter while someone turns the key. At least that way you'll know if the problem is in the starter, or in the ignition circuit.
Sounds very sensible and fairly easy to do. I will try that tomorrow morning. Thanks again for the help fellas....................lol
I've said it one and I'll say it again..............
Lucy, you got some spaining to do.............:biglaugh:
