Visual difference between stock and aftermarket pistons
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
My JE's have a engraved logo... CP's do too...
turbodriz;937860 said:
Brother man.... I hear u but I only understand what ur saying a little bit.
I want to try to Identify them while they are still in the block.
Driz: In a stock cast piston the valve reliefs are cast into them
In a forged piston most times they're machined in with a cutter
Look at the valve relief and you should be able to tell if they're stock or not.
in other words still in the block...
pulling the head is easy, taking the block aparat and putting it back together properly is not...
MK3Brent
Very expensive....
Aug 1, 2005
2,878
rtrdpenguin;938898 said:
Wow so you can see the pistons when they're still in the engine? I had no idea...
Borescope through the sparkplug hole / Or looking through the bottom with oil pan off.
Taking the head off means ALOT of replacing of parts and machining.
I mentioned looking up underneath the piston skirt as this would only require dropping the pan.
hth.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
its unlikely that your going to be able to tell without disassembling some of the motor. unless your superman and can see through the block....
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Dropping the pan is not an easy task just to see pistons but it is the best, and possibly only way other than pulling them out of the block. All aftermarket Piston's I've seen have their logo forged under the skirt as Brent said.
