Well, got the engine swap done on my 87 Supra just to have the alternator fail. Replaced that and everything seems good.
However, now when I was driving it (first time on the road with it in 2 years and I bought it dead... so no idea about any maintenance on this car) it began making an odd sound from the front driver side tire.
Its kind of a thump thump thump that increases in tempo as the car speed increases. Will continue making the sound if I take it out of gear and coast.
The sound gets sharper and louder if I turn to the right and will decrease a bit when I apply the brakes.
I don't have very much experience with these front ends and I do have a leaking power steering pressure hose (but I don't think its related to this).
Any ideas what might be the issue? Its kind of scary so I wont be driving it until I fix it because it seems to be getting worse with time. Almost sounds like its hitting something as the tire rotates but its not once per tire revolution. at about 40 mph (60-70 kph) it starts sounding almost as fast as a drum roll.
Thoughts about what I should look at first? I had the wheels off and the calipers/rotors looked okay but I didn't closely inspect the rack.
Just thinking.. are there u-joints in the steering rack? I have never taken one apart to look at the components, but there is a rubber boot I believe that has a rod that comes out of it. Wondering if I could have a bad steering rack...
