valve stem fell...keeper question
cinciguy89turbo
Zero to Sixty
Apr 7, 2009
139
Cincinnati, Ohio, United States
Wayne G.;1375247 said:
Did the valve fall all the way in and is loose in the cyl.? If it did the head must come off.
I'm almost 100 percent sure I can't see it with flashlight or anything. I paniced when it happened and turned the crank to see if it would come back up...felt a little resistance and stopped....figured it got jammed...:3d_frown:
rayall01
901
Westfield, ma
Damn, I hope it didn't get bent! If that's the case, you will have to take the head off.
HommerSimpson
1,067
New Smyrna Beach Florida
can you take a small phillips screwdriver about 6 inch long and just slide it down the guide and see if it hits the tip of valve... or goes all the way threw...if the valve is still in the guide.. theres a 50/50 chance you can still get it back up with out removing head...
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
Aggreed, a length of (coat hanger) wire bent with a small hook on the end thru the spark plug hole you could work it back up into place -----
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
In Soviet Russia; Valve Drop You.
dumbo
1,913
Albera, Too Far North
I hope your kidding, how would you get a hook down there? You know the diameter of a valve tem?
rayall01
901
Westfield, ma
dumbo;1376274 said:
Patiencently waiting:)
But he prolly could of had the head off and on by now.:naughty:
It's only taking this long, because a demonstration had to be set up, and we could only get together on Saturday to do it.
dumbo
1,913
:biglaugh::biglaugh:
cinciguy89turbo;1376317 said:
what the hell kind of socket do I use for the damn studs! It looks like a 14mm. But none of mine fit down in the space provided. Is there some specific socket I should be using?
Take it to a shop, or be very glad rayall is coming, and ask him to bring a 12point socket for WHEN YOU TWO FAIL AHAHAHAHAH
Nah I just kid haha.:naughty::naughty::biglaugh::biglaugh:
EDIT: Or do you mean you physically can`t get it on. If so, take the cams off.
cinciguy89turbo
Zero to Sixty
Apr 7, 2009
139
Sockets won't down in the hole to even get an accurate size, and he's not coming up here lol I wish someone would come up here that knew exactly what they were doing to take off this head, put my springs back on and put this head back on for me....
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Actually dumbo, you fail. Its not a socket. According to the tsrm, you need a special tool. (SST 09043-3810 from the dealership) or you can use a standard allen key bit on a 3/8 ratchet. 10 mm if I recall correctly.
EDIT: Hes taking the head off b/c he dropped a valve while working on it. I'm pretty sure he has the cams out already.
