Valve Clearances & Performance
Kai
That Limey Bastard
Been searching for a definitive answer to this, but...say the valve clearances are out of spec - either too tight, or too loose, what sort of symptoms & impact does this have?
I'm guessing poor acceleration & throttle response as well as ticking noise?
radiod
1,342
Abbotsford, BC
I know too tight and you risk having the valve stuck partially open. Not sure if too loose affects anything other than excessively loud valve train and over time possibly extra wear on the cams. I guess they wouldn't be opening as far though either so technically it wouldn't be flowing as much air.
toyotanos
What will we break today?
2,841
Coon Rapids, MN
Tight=hung valves, burnt due to lack of cooling (by not contacting the valve seat), valve seat damage is also possible.
In Spec=happy engine
Loose= possible spitting shims if the cams are aggressive/high rpm, noise, lack of performance, emissions testing failure.
Smashey
88
Grande Prairie
i remember reading that bucket shims from a honda atv or motorcycle, have the same dimensions as ours for a lot cheaper. Other vehicles as well but coudn't tell you what from sorry man hope this helps.
Matt
te72
Classifieds Moderator
6,602
WHYoming
91 1jz;1866646 said:
Ya my lifters tick a little too right now ive just been putting locus oil in
How's that been working out for you? I'd read through the oils and lubrication sub-forum sticky threads before putting in another drop of that stuff. ;)
Orion ZyGarian;1866620 said:
Do 1ZZ shimless buckets fit? Does anyone know?
1SZ-FE 1000cc Echo
13751-23030 5.12
13751-23040 5.14
13751-23050 5.16
13751-23060 5.18
13751-23070 5.20
13751-23080 5.22
13751-23090 5.24
13751-23100 5.26
13751-23110 5.28
13751-23120 5.30
13751-23130 5.32
13751-23140 5.34
13751-23150 5.36
13751-23160 5.38
13751-23170 5.40
13751-23180 5.42
13751-23190 5.44
13751-23200 5.46
13751-23210 5.48
13751-23220 5.50
13751-23230 5.52
13751-23240 5.54
13751-23250 5.56
13751-23260 5.58
13751-23270 5.60
13751-23280 5.62
13751-23290 5.64
13751-23300 5.66
13751-23310 5.68
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Damn, gold mine.
I'll probably be doing my valves this weekend. I've got some spare shims, and of course the full complement that's already there, but now at least I can get the ones that I need.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
IJ.;1866812 said:
1SZ-FE 1000cc Echo
13751-23030 5.12
13751-23040 5.14
13751-23050 5.16
13751-23060 5.18
13751-23070 5.20
13751-23080 5.22
13751-23090 5.24
13751-23100 5.26
13751-23110 5.28
13751-23120 5.30
13751-23130 5.32
13751-23140 5.34
13751-23150 5.36
13751-23160 5.38
13751-23170 5.40
13751-23180 5.42
13751-23190 5.44
13751-23200 5.46
13751-23210 5.48
13751-23220 5.50
13751-23230 5.52
13751-23240 5.54
13751-23250 5.56
13751-23260 5.58
13751-23270 5.60
13751-23280 5.62
13751-23290 5.64
13751-23300 5.66
13751-23310 5.68
Wow Ian, thanks! F*in saved. Why do anything but?
Also, you must be a man of incredible patience, having copy/pasted this for 4+ years now :p
te72
6,602
WHYoming
