Upgraded turbos and gas mileage
OneJoeZee
Retired Post Whore
aboard the Argama
Maybe it's just me... but did anyone else notice a significant increase in gas mileage after they upgraded from stock twins? :)
I regularly see about 30-50 extra miles per fill up compared to my stock twin setup.
It's just the way I drive the car now. Before, I used to be WOT everywhere 'cause full boost was there on tap at anytime. But not anymore. It's not bad, just different.
-1st gear is useless. Won't build full boost in 1st.
-2nd gear revs out for me around 70ish@7500RPM. On the street, I can't do that. 70 in a 45-50 zone is bad news.:biglaugh: 2nd gear is great for on ramps though.
-3rd revs out over 100, so that's bad too. :biglaugh:
-4th will have me doubling the speed limit with ease.
I find myself doing a lot more relaxed driving and cruising, which isn't a bad thing.
kbye,
Shadow
87 1JZ-GTE Single Turbo
May 25, 2005
304
Windsor, Ct
Yea, I noticed it too. It's because the stock twins spool earlier. Whenever you're in boost, fuel consumption is higher then when not in boost. So if you have a turbo setup that spools in higher rpm's, then you won't be using as much fuel when cruising around.
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
Under vacuum, the 1JZ is a fuel sipper. A 2.5 burns less gas than a 3.0 because less air in the chamber, less fuel required. Under boost, more air gets stuffed in and more fuel is needed. Duh. As Shadow said, if you build boost later, you'll use less gas. It's like comparing a GE to a GTE.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
Might as well be an on/ off switch.. Feeling like some boost? well flip it on and enjoy the 1JZ-GTE, then conveniently after youre done turn it off and enjoy your new found 1JZ-G(-T)E :)
My friends RB25 (big single) is like never under boost in his S13 unless were out on the freeway or he's pissed and he enjoys significantly increased mileage than the stock setup where power was pretty much anywhere you decided to just tap the gas a little (bye bye fuel all the time rather than here and there).
Upgrade FTW, just a better way of doing things. Wish I had money for a single..
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I noticed when going from stock ecu, to standalone, to GT40, to GT40 1.5JZ, my gas milage stayed the SAME where power roughly doubled. That was in the city. On the highway, I get about 30% better milage.
That was until recently. For some unknown reason, My car suddenly started getting about 30% increase in gas milage around the city too. I don't know what changed, but I like it.
EvoLuTioN
no-JZ Your Mom!
Mar 10, 2006
508
Bed
maybe it finally noticed its not lugging that 7M thing in there anymore
Shadow
May 25, 2005
304
Windsor, Ct
:yelrotflm:yelrotflm:yelrotflm:yelrotflm:yelrotflm:yelrotflm:yelrotflm:yelrotflm:yelrotflm
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i noticed my car got better MPG's after going to the 60-1 too. Stock twins spool too fast is what the problem is. i mean for the first few weeks i got WORSE gas mileage than on stock twins but thats just cause i was enjoy ing the single :evil:
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
I'm still on stock twins and 90 percent of the time the car is on boost but still get decent gas mileage. Single or twins, if you don't floor it all the time you will get good gas mileage just my 2 cents.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Almost impossible to do though :D
One time when I drove to VA from NJ and I got 28mpg on the stock twins with the silencer in my muffler.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
My supra is my "fun" car. So MPG isn't usually on my mind when I'm in boost. I DD an IS300 (which actually has worse MPG than the supra, but is very comfortable).
I'm curious what my MPG is going to go to when I put on a T04E 57trim.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
When we were tunning my car, we spent almost 30min tunning the low. WOT took almost nothing. My gas mileage did get better then when I was with stock twins.
I come on boost very quick though, so to have some boost on every gear and getting good MPG is "F"in' awesome.
OneJoeZee
Retired Post Whore
aboard the Argama
mattsmall;884028 said:
its because your in vac more often since the single turbos dont build full boost at 2200rpms.
I know that but what I was getting at more was because the powerband is so different, I have less chances to actually use full power and WOT. Almost never on the street and only sometimes on the highway. The mileage I'm getting now, I've done it before on stock twins but it was really a task to even try to do that.
I like the way the car is now. It's very tame until I really want it to be otherwise.
