Overview: I seem to be having a weird little tuning issue that I am trying to wrap my head around. I have done lots of reading on the TCCS and particularly the learned value correction (vf), but I can't determine which inputs may be causing my symptoms. Maybe my symptom is not directly caused by the TCCS correction, but why the symptoms happen at the exact same time the vf changes is what I am trying to use to help narrow down the cause (could be on the completely wrong path though).
Related Mods: 3" turbo back exhaust, lexus/550/afpr, CT26 60-1 trim, FMIC, manual boost controller, 3 angle valve job on rebuilt head with NA cams. autolite double platinum plugs gapped at .32 (same symptoms with NGK's)
-Lexus screw turned all the way out, base FP set at 32 (with vac), running 10lbs of boost
Symptom: Upon first start up for the day my VF will be at 4.95. It will stay at 4.95 during cruise and will have a rough idle and will start bucking at low RPMs. It will stay like this all day long unless I shut the car off, pull the efi fuse and reset the TCCS. After resetting, I will restart the car, it will show 4.95 for a split second, then stay right at 2.75 all day for as long as I keep the car running. When it's at 2.75 the car runs great, no more bucking, lumpy idle, pulls much more smoothly in boost. But as soon as what seems to be me letting the car idle for a period of time or shutting the car off the car goes back to the same symptoms of lumpy idle and 4.95 vf. It's like my short term correction is perfect, but as soon as I shut the car off and it reverts to the long term (if I understand it correctly) it has issues until I reset the TCCS again. Does anyone have any suggestions on where to start looking?
What I have done: Boost leak tested entire system, turbo inlet up to 3000 pipe thoroughly. Took off throttle body and cleaned throttle plate, set throttle stop srew, and tested dashpot and IACV via TSRM. My TPS may need to be adjusted, but it does not set a code. I have no codes at any point in time, even after driving a couple days without resetting TCCS. Cam timing is lined up with marks when #1 at TDC. ign timing is spot on 10*.
Thanks for taking the time to read in advance...long post, but wanted to get it all out there. Just looking for suggestions on what to try next. I will always report back to the thread and give results of the diagnosis as any help is much appreciated! There is a very limited amount of import tuning help in my area.... : (
