Two stepping?
TargaMK3Turbo
Money pit thats worth it!
Jun 11, 2007
235
Lambertville, MI
So, I'm kinda electronically retarted. How can I install the MSD box? or is that MSD box specifically for 2 stepping?
My guess is they are universal and you have to make them work.... Which I dont know what to do..
Thanks for all the info so far.. Some of it's helped.
drjonez
the motor city
www.4cefed.com
geez. here's some facts:
-only a few ways to 2 step w/the stock ECU: MSD DIS 4 and MAP ECU. a separate aftermarket rev limiter engaged momentarily may work as well....
-the phil long 2 step for the MKIV will NOT work.
-2 stepping shouldn't damage your turbo or manifold, true anti-lag will.
TargaMK3Turbo
Jun 11, 2007
235
Lambertville, MI
Hmm, s383mmber just told me it will eventually kill my turbo.. So your sure it wont hurt it? Sorry for the dumb question, I just want to be sure..
Is adding a 2 step to a almost stock MK3 worth it?
Dec 3, 2003
6,653
Canada
Yes it is. If you can build boost off the line, you will gain time (if you have slicks) You will blow off the street tires so don't bother with that.
PS: I haven't seen any turbos blow due to antilag/2step. I ran a 2 step on mine for years. (Now have antilag :))
Duane
mkiiitnr
Big Sinlge
Mar 24, 2006
25
kansas
damn gizzmo launch control would have been good only it doesn't work on toyota correct me if i'm wrong because we have a feedback system
supraboy
77
washington
a MSD ignition digital-6 plus, programmable 2 stage rev- limiter, high speed retard, and cd ignition, you can also hook up a linelock. will also work for 4,6,8 and odd cylinders...
will something like this work do you think?
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
MSD DIS 4, has been stated in 2 posts in this thread so far....
