Transmission can't shift while motor is running
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Okay... I guess I don't understand this, but I bled the slave cylinder system. that is good. I am watch as the fork pushes the throw out bearing and moves. I can't get it into gear though... did I place the clutch disk in back words?
I can shift while the motor is shopped but not in gear..
Any noises?
Did you check to make sure the clutch spun freely on the flywheel to make sure its on the right way?
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
I did not check which way it went, but ti looked obvious which way to put it on. I even went and looked on ondemand5 and found out I am pretty sure at least I put it on the right way.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
So, I went to start it in gear and it is like, "thud, thud,thud,thud." As my times as I crank the motor it thuds. I really think I may have put the disk i back words... only thing I can really thing of guys.
---------- Post added at 12:10 AM ---------- Previous post was at 12:09 AM ----------
hvyman;1530162 said:
Fat part towards the pp?
Fat Part? Picture please.
---------- Post added at 12:12 AM ---------- Previous post was at 12:10 AM ----------
From what I remember yes, i know what you mean.. I think I will pull the transmission if I don't get anywhere soon.
90T04
Tucson, AZ
www.azsupras.com
Is there any way that there could still be some air trapped in there? I had mine do the same thing, it was a new southbend clutch and I had the exact same symptoms. I bled the heck out of it and finally the throw got a little further, enough to fully disengage it.
gelboy1015
Vroom Vroom!
Jan 1, 2007
234
Houston, TX
Yea, its a bummer. I assumed the trans was assembled correctly by the previous owner (bought the car non running, but with a new clutch)... but it wasnt. So I had to tear it all apart again and reassemble it. Now its great, lol.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
Alright transmission is out. Here are the pictures, and it appears I even placed the clutch disk in correctly, so here they are, I still do not know what is wrong. All the clips as well seemed to be there.. man oh man. By the way, no fun removing the transmission from the car, I would ather pull the motor..
This was facing the pressure plate so I know I placed the disk in correctly.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
IJ.;1530486 said:
Looks backwards to me...
Pic of the flywheel/bolts please.
Uploading them now IJ. Also when i took the pictures, I am not sure if you're looking to see if the disk was hitting the bolts, but they look a little scuffed..
So the way the disk is on switch it?
Turn the disk on the flywheel to see if it his the bolts. It looks like both sides are the same almost.
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
---------- Post added at 05:50 PM ---------- Previous post was at 05:50 PM ----------
Brb:
---------- Post added at 05:53 PM ---------- Previous post was at 05:50 PM ----------
Fixed. I had the disk is the wrong way. I should have taken the time to do it correctly. When IJ. said, get pictures of the flywheel bolts, I sort of had an idea of where this was going. Thank you guys, I will put it back together and it will be running. Have a good day.
