Tracking Down a Stupid Squeak
Turbo Habanero
4,229
Tucson,AZ
So guys i figured i'd move on to my next issue since i finally fixed my harness issues :)
It's not a big one but none the less one i'm having trouble getting the problem to go away.
I'm running a Stock Fan Clutch (Autozone brand) and Water pump with a Dayco Belt
Every time my Fan clutch is engaged my Car sounds like a Metro Bus Super Loud but that's not the issue when this is happening my belt well start squeaking like no other.
I've replaced belt fan clutch and water pump recently (last 1500miles)
Ive tried to tighten the tensioner and loosen it also with no avail.
Does anyone have any tips or trick for me it would be great.
I think my next thing would be going to Toyota for a brand new OEM Fan Clutch
Jyrydr
I Wanna Go Fast
May 26, 2012
27
Western Australia
Not your power steering? Is it worse when you turn? If so check belt and for leaks.
Probably not if your sure its on the fan belts cycle. Worth a look if your not.
Thats what mine was, worn belt, then blew a hose, still noisy, belt was loose, still squeaks(just a chirp) at full lock, should just be my widey's, to much load or belt tension still a bit off.
Turbo Habanero
4,229
Tucson,AZ
My PS doesn't work but the belt is there i just have to keep adding fluid due to a rack that is pretty bad.
I'm pretty positive it is the belt on the Fan and Alternator becuase it goes away if i put my E fans on and remove the fan clutch. Also turning has no effect on the Squeak.
Just acceleration and when the fan clutch gets noisey
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
shouldn't you be replacing/ fix that P/S issue first :p?
Back to topic, sounds like bad fan clutch. Does anyone have a good one around you that you can use to test, process of elimination can save some $ and time :)
Turbo Habanero
4,229
Tucson,AZ
I should be but i need to purchase a new rack and power steering lines and set some time to just pull the motor to make it easy on myself for replacing
As for some one having a extra the only one's are in use on there cars but i'm sure they would let me use one for a min to see
Turbo Habanero
4,229
Tucson,AZ
jetjock;1861311 said:
Keep swapping parts until it's fixed! ;)
Will do next is another belt and water pump.
Also the sensor on the thermostat housing closest to the fan blades is leaking out the sensor now lol and I don't mean its leaking from the treads its actually leaking through the area with the clip plugs in
Turbo Habanero
4,229
Tucson,AZ
jetjock;1861341 said:
You missed the sarcasm Jordan. Swapping parts is never a good way to solve problems.
oh I did Lmao.
Well i figured the parts where cheap enough.
Andy i've tried to loosen it with no avail
radiod
1,342
Abbotsford, BC
Take accessory belts off one by one when the squeak is there. When it's gone you'll at least know where to be looking. Also make sure all your pulleys are clean and the belts aren't dried up.
Turbo Habanero
4,229
Tucson,AZ
I only have one belt at the moment :)
And i cleaned the pully when I pulled it earlier today. The belt is about 2 months old.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
What do you mean by "each time my fan clutch is engaged"? So any time your car is idling or at low rev, it squeals? The only time the fan clutch is "disengaged" is at higher revs where the fan freewheels. Sounds like it might be your AC belt, squealing when your AC kicks on (provided you have that still installed).
Do all of your belt pullies turn smoothly? (including idlers, alternator, power steering, water pump, AC)
Turbo Habanero
4,229
Tucson,AZ
Ok I was wrong what I meant is anytime I can here the fan clutch come on or become louder the belt will squeak but will not do it as soon as the fan quiets down.
I figured its the clutch kicking on to cool the car.
Also I do not have a a/c belt.
And when i run electric fans instead of my fan clutch the belt never squeaks.
