I found out a local junk yard had a is300 in it, so I went down and got the coils, plug wires and wiring, only problem the harness had been cut, can somebody help me out with wiring the coil plugs into the stock 7m coil pack plug?
supraman502 said:I found out a local junk yard had a is300 in it, so I went down and got the coils, plug wires and wiring, only problem the harness had been cut, can somebody help me out with wiring the coil plugs into the stock 7m coil pack plug?
Not with the coil packs fully bolted in with some brackets he made. I actually read through the whole thread.... though I did it without dinner and was rather dizzy.boltz said:i did mine the same was as tookwik... and he provided pics already somewhere in the 19 pages...
starscream5000 said:I still think this should be cleaned up and moved to the tech section.
Jeff Lange said:It will be.![]()
See post #81, then see post #1Inygknok said:Not with the coil packs fully bolted in with some brackets he made. I actually read through the whole thread.... though I did it without dinner and was rather dizzy.
Inygknok said:Ok, just had a quick look inside the car to clarify my suspicion. I guess I'm a bit dense for not noticing that the back, huge bolt that holds on the spark plug valley cover had a thread in the middle. That's why I couldn't figure out, cuz I had never noticed it before.
Couldn't I just tap the other one that needs to be threaded?
Hehe, thanks for that actually! I was planning on dropping by the Toyota shop tomorrow.bryanintexas said:Buy another rear one #90341-24007 $6.23. :biglaugh:
