To jack up the supra... (Need Help )
Ryan
125
Waterford
Can I use the stock car jack to lift up the axle so I can put Jack stands under it to check the diff. Fluid and tans fluid?
Is it strong enough and where is the best place to put the jack at?
I also have a 2 ton floor jack but its kinda small and im not sure it will lift it high enough.
Quick response is appreciated as I am trying to ge the work done today and tomorrow.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
Holy hell no!
Use your floor jack, and lift on the Dif. Then put the stand where they're SUPPOSE to go.
Sawbladz
1,727
Oshawa, ON, CA
hvyman;1293891 said:
or lift on the pinch welds on each side since there the lifting points on the car.
When making statements like this please make sure to explain to only use the scissor jack for this specific jack point. We don't want to have him try this with his 2 ton.
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
thank you! my pinch welds are all jacked up from the previous owner :[
shaeff
Kurt is FTMFW x2!!!!
11
Around
Jack and jack stands. Never crawl under a car that's supported by only a jack. Not blocks of wood, not cinder blocks, jack stands.
If you don't have proper equipment, then don't do the work. Your life depends on it.
Ryan
125
Waterford
I used jack stands and i know enough not to just trust the jacks.
The problem is the guy that my parents used to have work on the car( the guy that charged them over $25 to clean the throttle body) was an idiot and bent part of the pinch welds.
I ended up just sliding the jack down farther and putting the jack stand on the other side of the bent pinch weld.
Does anyone know what tools I need to get the diff. and tranny plugs out so i can check the fluids? sorry for all the dumb questions.
Sawbladz
1,727
Oshawa, ON, CA
This complicated tool known as a socket paired with the rarest of all tools...a ratchet. Put together they are unstoppable.
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
Haha,and the question is:how to answer a silly question.LOL
Ryan
125
Waterford
What I ment was.... does anyone know the size? Because Im gonna be borrowing tools so an idea would help.
Thanks
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
Thanks
I believe they are 19mm,could be wrong.I'll go out and check tomorrow morn if nobody posts size before then.
earlingy
Huntsville
I removed my diff drain plug with a 24mm socket today, but stripped my fill plug with a 24mm socket. Don't know if it was too big (I did try a 23mm but couldn't get it on), or maybe I just came at a bad angle.
Sawbladz
1,727
Oshawa, ON, CA
Sounds like you did them in the wrong order. How do you plan on filling that diff now? Were you able to get the fill plug out?
