To Bore or Not to Bore?
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
thank you SupraCentral.
But I still need answer,do I NEED to bore cylinders or am I good with STD bore?
Wayne G. i've wrote it in Kilometers, in Miles it should be around 160 000 - 170 000 :)
Supracentral
10
Honestly, the only thing that can answer that question is a micrometer.
With that many miles, over boring is likely needed unless the car was maintained very well.
starscream5000 said:
It would be best to have a proffesional machinist take a look at it and decide if you can't.
Probably the best advice you will hear all day right there.
Doward
4,245
Alachua, FL
Clarkston, Ga, you say? Not far off from I75 (which happens to run real close to Gainesville, FL) I'm still looking for a reputable shop, when it comes time to rebuild my 7M - and I certainly want someone with a freakin' torque plate!
No problems with taking a road trip, here.
SC's right - It doesn't matter if you have 10k miles or 200k miles - you must measure your bore diameter to determine if you need to bore or not. Although, if you really need a bore after only 10k miles, you might track down why that is ;)
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
heh, oh well I'll just have to go with what my mechanic says. So possibly supra will be down for another year as parts from US travel to Lithuania for nearly a month :/
Thanks anyways ;)
Supracentral
10
What you need to do is follow the procedure below in sections 4,5 and 6.
If you can get your hands on a micrometer/cylinder gauge this doesn't take long at all.
