Tips for winter storage
Sil
Evil Empire
Jan 13, 2008
340
Milwaukee/Chicago
Jack stands, full tank of gas and a trickle charger if you don't plan to start the car from time to time. Fuel stabilizer is a maybe and you'll get many different responses on that one.
kikdurazz
what's the birdcage for?
winnipeg
I don't bother with jackstands anymore, that was more for the old days when tires were quite prone to flat spots. I usually just pop the tire pressure up about 10 psi before putting it away. I do add fuel stabilizer, more important for summer storage but fuel does start to go bad after 6 months (less so in colder climates). Wash and wax the car, if stored outdoors get a soft cover, if indoors make sure it is not going to be prone to heating and cooling constant temp is the best. Plug the exhaust with a rag to keep rodents out. Don't put the E-brake on Leave it off. Remove the battery. I like to do an oil change prior to storage, full tank of gas and check all other fluid levels. In cold climates I would make sure that your coolant is proper as well.
I'm sure there are more things that others do. I have winter stored my car outside for the 12 years I have owned and never have trouble in spring.
Insert battery, fire and drive.
This has been covered every year for the past couple years I've been on the boards...
All tires are prone to flatspots if not used...
