Throttle cable for 2jzge stock manifold?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
What throttle cable is required for a 2jzge with a factory intake manifold? Also I think I need the throttle bracket on the throttle body for a LHD car... Anyone know where I can get one quick?
Reid
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
lilazni3uoy;1155551 said:
you can get the bracket off of any sc300 from the junkyard as of the throttle cable, using the same ones from sc300 or n/a mk4's will work since the length should be about the same
Ok sweet. Its going to be hard to find an SC300 in a junk yard in Reno.
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
You can also just use a bicycle brake cable and use the fittings off of your stock 7mgte cable to connect to the throttle pedal. Cut the cable and sheathing to length and then solder a nut on the throttle cable end to give the pedal something to pull against and you're good to go.
