There went my 'good tune'
isnms
United States of America
Oklahoma
i80.photobucket.com
I decided to try out the Rebic LC. So I installed it and had my S-AFR disabled. Everything seemed to be fine. With my mods, I had the dial set at 3, A/F ~11:1, boost ~11.5psi, 93 octane (first attachment). Felt great and everything looked good.
That was getting on the interstate. Five minutes later getting off the interstate, decelerating down the off ramp, it died. I cranked it back up and had a terrible lope. No acceleration. I babied it the rest of the way to work, about 1.5 mile. Looking at my vacuum reading at idle, it had dropped to ~16.7 and VF climbed to 3.5v (second attachment). I start looking for vacuum leaks. I could not find any. Then I decide to pull the dipstick out and it's blowing smoke like a chimney :(
I trailer it home and do a compression test:
[cyl]...[dry]...[wet]
1........180.....---
2.........85.....120
3........185.....---
4........185.....---
5........120.....150
6........120.....150
So now I have blown rings or ringland. Either way the motor has to come out.
DETONATION, but I don't know how. Must have been timing.
8,897
A loping idle is incorrect A/F. Make sure you have gone over the car completely. The ECU is trying to correct because you have the wrong readings.
You might have missed a hose somewhere. Or might not.
shaeff
Kurt is FTMFW x2!!!!
11
Around
my car will lope at idle like crazy even if i have a small vaccuum line detached. plug it back in, purrs like a kitten.
-shaeff
isnms
Oklahoma
i80.photobucket.com
Oh how I wish, but with the chimney like dipstick tube (blow by) and compression in 2.........85.....120 (rings or ringland), I don't think I have a chance. I have searched all the vacuum hoses and ic connections and have not found a leak. :dunno:
edit: Yeah. I was thinking, after that log getting on the interstate, things were going Great!! :wiggle:... :nono:
97TSiAWD
In need of more traction
Jul 18, 2006
124
Michigan
Sorry to hear about your misfortune.
So I take it that there is no software available to log knock counts with these cars?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I'm sure my meth injecton has helped me out with this hot weather and my heatsoaking AFM setup, whenever you get it back up and running again you might want to consider it. I love mine.
jetjock
creepy-ass cracka
9,439
Guess that igniter problem is sorta moot now ;)
Sorry to hear of this isnms. If it helps any I always enjoy your posts. Whether giving or asking advice they're well written, filled with helpful links or graphics and (unlike many) are actually coherent. It'd be nice if everyone did as well.
isnms
Oklahoma
i80.photobucket.com
Thank you all for the sympathy and those with empathy too ;)
I need to learn something from this and so far can’t put my finger on it. What was the cause? I thought I had a good conservative tune. Was not exceeding the boost reasonable for my mods. I had all supporting mods for this level of tune, so I thought. Only mods not installed yet were the fuel.
So help me out:
  • The igniter, that I can’t get to pass an ignition module test, actually is bad and missed a step.
  • The Rebic injector driver is driving 15 year old injectors w/ 15 year old pump. The injectors could not handle the greater duty cycle.
    • ^this means get my fuel mods done
  • The Rebic does something to the timing that my weak igniter could not handle.
  • Other
isnms
Oklahoma
i80.photobucket.com
That statement, that is posted in many places, does not seem to be accurate.
Instead, if you look at the scanned documentation:
GReddy Rebic LC Manufacture Documentation
At "0", the injectors will flow 5% less than factory ECU settings.
At "10", the injectors will flow 20%~25% more than factory ECU settings.
Indicates '2' to be stock setting.
http://www.mkiiitech.com/forums/viewtopic.php?t=955
suprashy
126
Nassau County, NY
isnms:
Sorry to hear about this.
Right now, I too have achieved a good self tune (11.2-11.5's), but one thing I noticed was that I was seeing 870 C EGT's under boost around the 5,500 mark. I immediately stopped testing after that. I am pulling from 22-28% on my S-AFC for my "good tune", and I think the ECU advances timing and is causing the high EGT's. (My timing @ idle is stock). My Supra gurus (I'm new to tuning), also agree this could be true. I think the 680's are too much for my HKS Sport 60-1 @ 15psi. I do have a PT61 on the way which I'm hoping will result in less fuel pulled via the S-AFC, resulting in less timing advance, yielding lower EGT's.
My question for you is did you have an EGT gauge? I know that this displays an average of all 6 cylinders, and tuning should not be done solely based on one EGT probe, but I'm curious if you knew what your EGT's were. I switched to colder NGK BCPR 7ES, and noted a slight 20 deg. drop in EGT's, and the car feels faster.
Please state your turbo/fuel setup, and what psi u were running during your last good run.
From what I've been learning, spark plug condition is one hell of a way to learn about the condition of your engine per cylinder, and I'm surprised I don't see too much of that discussion here. I have no probs. pulling plugs regularly, to ck. on the condition of my engine - its free! U may want to pull plugs and post pics. I think "spark plug monitoring" is essential, and I'm adding it to my "know what's going on in my engine" forte. Prob. with "spark plug tuning" by the time one notices detonation evidence on the plug, its too late. :( Small incremental changes in tuning I suppose would help.
I'm sorry, I haven't given you an answer, your situation is similar to mine right now - I'm looking at good A/F's, but there seems to be more to tuning than just that. You stated you have old plugs and injectors, but if they were not flowing correctly, your A/F's would lean out. Given what I've exp. I think possibly your timing is being affected?
If I've erred anywhere, please correct me. Good luck, and pls. keep us informed.
