There is a hole in my Intake Manifold! See pic.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Just the other day I could not boost past 10 psi. I didn't have time to investigate until now.
I started looking at vac lines and such and then saw this. I don't have an earlier picture to compare things to; but, I'm pretty sure this wasn't like this before my boost issue.
Could this be my boost issue...and what could've caused it to blow out?
I have a new tick also. Could this be related...hmmm...?
Thanks!
CajunKenny
Nov 15, 2007
3,255
Washington
I looked at my 87T and that manifold is different; but, the hole is plugged so I went out and looked at my 89T. That manifold is the same and has that hole plugged.
Now that I know that it's supposed to be plugged, what in the world caused it to blow out of there!??!
Next is to figure out what to use to plug it...
- Remove TB
- Apply appropriate size tap
- Screw in same size cap bolt
- Done!
shaeff
Kurt is FTMFW x2!!!!
11
Around
I've never seen it before. Looks like you ran too much NOS, but the welds on your intake manifold were too well done, so it blew that plug out instead. Don't ask questions, you lucked out, kid.
Now, I'll drag race you to them thar train tracks...
:sarcasm:
CajunKenny
Nov 15, 2007
3,255
Washington
Not running the juice. Not yet anyway... ;)
I haven't been around supras as long a lot of guys on here; but, in my short Supra life, I haven't seen this happen either.
I'm only at 13 psi of boost so I can't imagine it was that.
There's a hole in my manifold, dear J-Dub, dear J-Dub,
There's a hole in my manifold, dear J-Dub, a hole.
Then fix it, dear Kenny, dear Kenny, dear Kenny,
Then fix it, dear Kenny, dear Kenny, then fix it.
With what shall I fix it, dear J-Dub, dear J-Dub?
With what shall I fix it, dear J-Dub, with what?
With some taps, dear Kenny, dear Kenny, dear Kenny,
With some taps, dear Kenny, dear Kenny, some taps.
The taps is too long, dear J-Dub, dear J-Dub,
The taps is too long, dear J-Dub, too long,
Then cut it, dear Kenny, dear Kenny, dear Kenny,
Then cut it, dear Kenny, dear Kenny, cut it.
With what shall I cut it, dear J-Dub, dear J-Dub?
With what shall I cut it, dear J-Dub, with what?
With an axe, dear Kenny, dear Kenny, dear Kenny,
With an axe, dear Kenny, dear Kenny, an axe.
The axe is too dull, dear J-Dub, dear J-Dub,
The axe is too dull, dear J-Dub, too dull.
Then sharpen it, dear Kenny, dear Kenny, dear Kenny,
Then sharpen it, dear Kenny, dear Kenny, sharpen it.
With what shall I sharpen it, dear J-Dub, dear J-Dub?
With what shall I sharpen it, dear J-Dub, with what?
With a stone, dear Kenny, dear Kenny, dear Kenny,
With a stone, dear Kenny, dear Kenny, a stone.
The stone is too dry, dear J-Dub, dear J-Dub,
The stone is too dry, dear J-Dub, too dry.
Then wet it, dear Kenny, dear Kenny, dear Kenny,
Then wet it, dear Kenny, dear Kenny, then wet it.
With what shall I wet it, dear J-Dub, dear J-Dub?
With what shall I wet it, dear J-Dub, with what?
With water, dear Kenny, dear Kenny, dear Kenny,
With water, dear Kenny, dear Kenny, with water.
From where shall I get it, dear J-Dub, dear J-Dub?
From where shall I get it, dear J-Dub, from where?
From the well, dear Kenny, dear Kenny, dear Kenny,
From the well, dear Kenny, dear Kenny, the well.
In what shall I get it, dear J-Dub, dear J-Dub?
In what shall I get it, dear J-Dub, in what?
In a manifold dear Kenny, dear Kenny, dear Kenny,
In a manifold dear Kenny, dear Kenny, in a manifold.
jetjock
creepy-ass cracka
9,439
Lmao @ Ian...
Kenny: Yes, but better formulated. I'm usually not a fan of such repairs but when the need arises A4 puts consumer products like JB Weld to shame. Used all the time by the military and in aviation. It's serious stuff. Cheap and readily available too. Ebay has it. JB would work fine for your problem though ;)
InFrnt0fU
Lurking Supra Socialite
:biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh::biglaugh:
SWD Fredester 3
674
baltimore maryland
Hey Kenny, enough said. I'll send you the extrude honed plenum with a brand new OEM TB attached on monday. I also have a new DM manifold blue gasket
for the manifold that you can have.
