the t3d's FIRST "Performance before Appearance" BUILD THREAD!
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
7Mboost;1190545 said:
I'm gonna have to disagree, I couldn't get my rings seated until I started driving it hard. Take out your wastegate spring or anyway to stay out of boost, go out and drive it hard (obviously not bouncing off the limiter everywhere you go but don't be easy on it).
You can start the car with some accessories off, you have to check for leaks and problems first anyways. (So if any accessory you haven't put on has a possibility to leak I'd suggest putting it on).
Good luck with it.
You can disagree all you like, but by driveing the car up hills and makeing it work its actually seating the rings in nicely, revving it doesnt help anything and will only add to glazing the bore.Theres more than enough time after its all run in to play racer boy.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Your getting the wrong idea. Yes driving up hills and dropping the car to a lower gear pulling as much vacuum as possible is a good way to help seat the rings but it can take more than that, also my experiences are with chromium rings and in my case, needed more "racer boy" driving as you like to call it. Your are more likely to glaze the bore driving it easy if the rings are not seating.
(BTW- spell check is your friend)
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
man! its raining outside and it looks like it's gonna be raining for a while. i think i'm just gonna suck it up and drop the tank anyway. i started it yesterday and drained it, so i'll take some more pics and post them up
-t3d
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
ALRIGHT!!!!!!!!!!!
let's post some pictures!
ok i started by jackin up the supra for better accessibility of the gas tank
disconnected the fuel lines/hoses
started the draining process...shit was pretty nasty
while it was draining, i decided to go ahead and make my USDM TB all nice and painted :naughty:
this is the gasket that i have doesn't seem to be correct??
i was gonna bolt it on anyway, but i noticed that this bolt hole was stripped:cry:
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
MOOOOOOOOOORRRRRRRRREEEEEEEEE!!!!!!!!!
ok. i dropped the gas tank
haha put it on the creeper for easy mobility =0)
i started removing the fuel pump cause i need to install the walbro one and found this shit :aigo:
...disgusting!!!!!!!!:icon_evil
anyways...i started the process of installing the walbro pump. it looks nice :love:
other things that i did...
screwed in the wideband o2 sensor
found and installed the other part for the power steering pump adjuster...also painted it :evil2:
and this totally awesome part is called The T3d:love:
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
MOOOOOOOOOOOOOOOOOOOOOORRRRRRRRREEEEEEEEEEEE!!!!!!!!
here are some other little things that i need to clean and install....and paint:naughty:
and here are some pics of how the motor looks now :love::love::love::love:
GOOODDDD!!!!! i can't wait!
anyways...
my questions are....
if was just to install the new pump with out doing the relay mod, would i just leave it be and just install it? i'm still thinking about doing that mod, but i'm just curious....
and of course...the gas tank is disgusting. no one seems to make an aftermarket OEM tank, so i'm gonna have either clean it myself the best i can or get it professionally done and re-lined for like a $140 bucks:aigo:
but the sooner i get the tank done, the closer i will be...
LET ME KNOW WHAT YOU GUYS THINK!!
-t3d
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
damn...
i get more comments when i don't have pictures up =0(
anyways...i'm getting another tank tomorrow that is supposed to be clean for like a hundred bucks, so depending on what that looks like, i'll be using that and getting THAT much closer =0)
-t3d
Yep, that's where it goes.
Also, don't bother looking for an aftermarket tank, even if you find one you'll hate installing it. It's a major complaint with musclecars as they have a strap setup like ours and aftermarket tanks are never quite made the same as the OEM...
